I have an avi file on my HDD for a long time, and now I can't do anything with it(raname, move even delete it). I run a patch(or registry key; the file have 'exe' extension) for fixing avi bug in WIndows XP, but that didn't help. Also I try to remove all premision and add only administrator from security tab on properties, but that also didn't help. Can I make something to rename and move the file (that is what I want) or at least delete it when anything goes wrong.
Man it's been a long time since I posted! Try running the CMD console, going to the directory and using the "DEL" function to delete the file. The problem is sometimes when you try to use "My Computer" to delete a corrupt AVI, Media Player is still trying to read it when you select it and try to delete it, and Windows is too stupid to cease it. By using the CMD console, you bypass the whole integreated Media Player thingy.
Is this what you did?
Unable to Delete AVI Fix.
Open regedit and go to:
HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shel lex\PropertyHandler
Delete the value you find there.
This is due to XP (explorer in particular) trying to create a preview
for it. Now because the file is corrupted or incomplete,
it cannot read it properly, hence, it will not release the file.
This prevents explorer from doing this.
As usual, backup the registry key before deleting it.
https://www.videohelp.com/forum/viewtopic.php?t=225878&highlight=delete+avi+file -
jimmalenko
Yes. I restart many times and then try to delete the file, but with no success. This file stay on my HDD from a long time and from time to time I try to fix it. Now I am really tired to do this.
xtreemkareem
Your advise help me. Thank you! I don't use Media Player because this player is so stupid as Win XP is, so I have enough stupid programs on my PCI use BS Player integrated in KLite Mega Codec Pack 1.17 and the problem with "still trying to read it" stay. Maybe this is a bug in Windows and Microsoft may release a fix for it. Thank you again, man.
dcsos
I will try next time that what you say.(guess I express right) -
A program to remove stubborn files...a freebie!
http://www.gibinsoft.net/gipoutils/bin/moveonb.exe
It's called MoveOnBoot and will allow you to select the file in question and delete it when you reboot. -
Originally Posted by kocu
It never happens with the use of Virtualdub.
I had that problem several times. Sometimes it helps to change the extension from .avi into .txt and sometimes it could be deleted when you reboot in safe mode.
Sometimes I managed to delete them using the explorer within Vegas.
Sretno Bugarine!
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 17:07 -
need file rename tool
By sigpop in forum Video ConversionReplies: 2Last Post: 11th Feb 2011, 20:28 -
How to rename a file when it is in ntfs mode
By mysts in forum ComputerReplies: 3Last Post: 19th Feb 2010, 04:34 -
how do I rename avi title please?
By pjo123 in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2008, 14:34 -
Can't delete AVI file
By Fbee in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 21:25
