Hi everybody, I Have a question.
Well, I have some files .vob that play on the computer with PowerDVD, but I like to put this files (.vob) to a dvd, but I don't what have to do.
I think tha need other files like .info i don't now exactly.
Thanks.
You can import VOB files straight into TMPGEnc DVD Author - it has a fully functional 30 day free trial. IIRC you create a new project, then go to Add File, then change the "files of type" filter to all files. From here you can create menus if you like. This will output your IFO, BUP and VOB files in a VIDEO_TS folder for you.
If in doubt, Google it. -
To create a DVD you need to create a certain file structure and certain type of files. An authoring software will do this for you. TDA as suggested by Jim is a popular and good choice. You can also use DVDLab. There are others also.
Also see "What is DVD" & "How to "section of this forum for more details.When I was born I was so shocked that I could'nt speak for 18 months.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 09:52
