I try to copy some DVD, but it's not orginal, but i dont know why i alway get an error at certain percent can some one help me?....
Closed Thread
Results 1 to 14 of 14
ummm, yeah.
Hang on while I fire up my crystal ball .....
<brrrrrrm>
Now, you're trying to copy some burnt DVDs, yes ? (I assume that's what you mean by saying that they're not originals)
And you get an error at the exact same percent every time ?
What burning software are you using ?
What error are you getting ?
As the darkest of all stabs in the dark, I'd say you're getting a Cyclic Redundancy Check error, which means that your DVD Drive can't read the disc. If this is the case, try cleaning the DVD. Alternatively, try using a different DVD drive to rip.If in doubt, Google it.
All of his DVDs are burnt on Ritek/Ridata disks and cannot be read. I have the same problem with all of my DVD backups on Ritek/Ridata disks. I can open all the VOBs in VirtualDubMod OK but every other program gives me the redundancy error.As the darkest of all stabs in the dark, I'd say you're getting a Cyclic Redundancy Check error, which means that your DVD Drive can't read the disc. If this is the case, try cleaning the DVD. Alternatively, try using a different DVD drive to rip.
There are two options here. Either rerip the originals or spend hours recoding all the VOBs in VirtualDubMod and using VSO DivXToDVD and DVDshrink or TDA to reauthor and burn your DVDs. Reripping the originals is the quickest and easiest option.
Are you using labels coz i had the same problem but after much searching on this brilliant site i removed labels and hey presto sorted.
Don't use labels!!! If you have used them spray a little WD40 on the label leave for 5 mins and it will peel off.
Trust me i know this from experience.
Don't know how buying a new burner is going to help. I'm sure the reason that he is trying to rip them from a copy is because he doesn't have the original and the copy won't play correctly in his standalone DVD player.
The reason the copy won't play in his DVD player is because it was burnt on cheap media.
If he had the original, he could rip it again without getting the cyclic redundancy error and then burn to a reliable media that will play on his DVD player.
Sounds like bad media.
I rent this at a local store and im pretty sure this is not original because it is in a recorded disc. I dont know why everytime i try to copy it, it never finish it alway have an error. On the first disct it have an error at 98 percent and other is in the mid 50 percent. I use TDK dual layer dvd burner and using Nero and Roxio to burn it but same thing happen. The disc is fine because there aren't any scratch on it.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Cobra
***Warning Expired***Polo
My Dvd Video Disc is Protected, Couldnt copy the files..... ^_^
By syaoran7li in forum DVD RippingReplies: 21Last Post: 20th Apr 2012, 21:05 -
Copy Copy-Protected VHS to DVD
By abazabam in forum MediaReplies: 36Last Post: 12th Feb 2012, 03:25 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
