hi before when i used dvd shrink i to would burn files do dvd but now it just backs them up to the hard drive , how can i get it so that it burns again?
In your output settings, you need to select either your DVD Burner under the "Burn with Nero" section, or "ISO Image and burn with DVD Decrypter", depending on how you've got DVDShrink set up. I believe you can also burn with CopyToDVD if you have that installed.
If you're only getting the backup to your hard drive, then you probably have "Hard Disk Folders" or "ISO Image" selected here.If in doubt, Google it.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Ripping with SHRINK then BURNING with IMG burn
By efiste2 in forum DVD RippingReplies: 10Last Post: 17th Apr 2010, 00:39 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
burning with dvd shrink/imgburn
By angryassdrummer in forum Authoring (DVD)Replies: 4Last Post: 7th May 2007, 15:44
