Currently, I've got a 120G WD SATA drive as my boot/storage drive, partitioned 35/85.....
Plus I've got a 120G WD IDE drive, one partition, for capture/encoding. It's set as master on the primary ide.
Is this the best way to set them up? Or should I use the IDE for boot/storage and the SATA for capture/encode?
Everything works the way it is...I was just wondering if it would be faster swaped around.....
Thanks,
Bob T.
I think you answered your own question correctly ... dont you ...
Ide as master , with os installed
Sata , because its alot faster , is best for the captures . -
Dang.....I was hopin' I was wrong.....Originally Posted by Bjs
OK....not to big a deal to switch them around....
Thanks!
Bob T.
how to re-anable my sata icon in win xp sp3 (sata drives not visible in DM)
By deejay.2001 in forum ComputerReplies: 7Last Post: 11th Mar 2011, 10:47 -
IDE and SATA
By HotDamn! in forum DVD & Blu-ray RecordersReplies: 11Last Post: 6th Mar 2010, 01:49 -
sata vd ide
By dymx in forum ComputerReplies: 3Last Post: 9th Sep 2009, 09:04 -
Sata v.s IDE
By tapal in forum ComputerReplies: 4Last Post: 22nd May 2008, 06:04 -
IDE + Sata Drive ?
By StoneColdWhat in forum ComputerReplies: 4Last Post: 17th May 2007, 16:50
