I'm a newbie so if this has been answered before I apologize. I've downloaded avi files of a television series, there are 20 episodes at about 50 min. each. I've converted the avi. files using VSO DivXToDVD. What I'd like to do is put five episodes each on four DVD-Rs. I'd like to create a simple menu that either lists the episode names or shows them like chapter stops. Is this possible and if so what programs steps should I use.
Thanks!
import the vobs in tmpgenc dvd author and make the menu.
TMPGEnc DVD Author > Add DVD Video. Then you can add your VIDEO_TS folders.
If in doubt, Google it. -
Thanks for the quick replies! That's exactly the program I was looking for. One thing though, it seems that the five episodes are slightly too large to fit on one DVD-R, is there a way to shrink them or do I just have to put only four on instead?
Hi
TMPGenc DVD Author as already mentioned. Put all files and click ignore "output greater than....................." in DVD author. Then use DVD Shrink(Freeware). the more episodes you put on and the more you shrink the file the greater the loss of quality. Typically 4-5 is the most i usually do but give it a try.
Glue/Stitch a series of .avi files...
By midiw in forum ffmpegX general discussionReplies: 2Last Post: 23rd Jan 2011, 14:03 -
HELP - Converting DVD to avi for Samsung B650 series TV
By danielo in forum DVD RippingReplies: 8Last Post: 19th Nov 2009, 15:52 -
Help with splitting episode series to avi.?
By video_man2008 in forum DVD RippingReplies: 18Last Post: 15th Sep 2008, 01:48 -
Want to burn AVI TV Series on DVD
By koenf1 in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 17:36 -
TV series ripping to xvid issue (newbie question):
By Jestrixx in forum DVD RippingReplies: 4Last Post: 11th May 2007, 13:37
