My friend want to make DVD's![]()
But he is worried that his HP computer with a 333MhZ Celeron CPU can't do the job.![]()
Since my computer has the same CPU (but more memory) I have run it in to this problem, but, with making VCD. I have a 32X burner, but, if I go above 4X the results are very poor.
Can the same happen burning a DVD?
Or are there other factors that come into play?
To trancode a DVD with DVD2ONE DVDshrink or cloneDVD it will work but it will take a long time.. Maybe little wore then real time.
If your doing a capture. It all comes down to how you capture. I have a Dazzle 2 and they say to have a P2 400 to capture MPEG 2.
TO authorize a DVD my P2 400 can do it but it's very slow.
You really have to give more info on what you want to do. -
He wants to take his 8mm camcorder tape(s) and put them on a DVD.You really have to give more info on what you want to do.
He has the (parallel port) Dazzle to import/edit the video(s) on his computer.
And I think it can render the output in the MPEG-2 DVD format.
Or if not, he also has NERO 6 which I think can also convert files to MPEG-2 DVD fomat.
So, what it comes down to is. Can his CPU handle the load of conversion and burning a DVD? -
No,time for a new PC.
Most video and burning software requires:
Win98SE or newer
256MB RAM
550MHz CPU
7200RPM HDD
BTW...4x CD writing=600KB/s,4x DVD writing=5550KB/s -
NO way to use parallel port to import video. either a capture card or a camcorder with passthrough and firewire card in pc
anyway, time for a new one, I have a laptop, 800Mhz and is a pain in teh butt to encode even to mpeg1, sooo slow.
what he needs....minimum:
1.6 or faster cpu
512Mb ram
80Gb or more hdd
capture card or firewire with a passthrough camcorder -
Say what ???
A celeron 333 , no way .
Not to dump on your friend here or you , but there dose come a time when people need to consider an upgrade , really .
I bought a p3 800 in ebay , complete system for $330 + $40 for tansit a year or so ago , and upgrade the motherboard + cpu + ram for a little under $340.00 , this is where you need to be if your dealing with dvd .
The p3 800 on its own is capable , but if you want to bring in good quality captures , then the minimum specs for cpu is 2000mhz (actual clock cycle) , athlon xp2400 cpu meets this just .
There are a number of pci capture cards available at good prices now , but I do highly recomend any that virtualdub can capture from .
The p3 800 was tested with fly3000 in raw mode , and you need about 45 gig for 2 hours . Then an asus v6600 vivo , which has its own propriety codec for compression , but vitualdub is able to use it , and the results here were pretty good , a lttle under 3.8 gig was consumed in capturing the 2 hours .
Yes , in full pal resolution (720x576)
And as for those who say you need oodles of memory , nah to you lot , the system only had 128mb's , so there ...
A p3 800 can handle transcoding and burning the dvd project , but will take time to transcode the files , and SLOW the burner right down , or else .
As for transcoding input video to dvd quality mpeg2 :
Has anyone here ever considered frameserving from virtualdub to bbmpeg ???
Bbmpeg outputs HIGH quality dvd mpeg2 files , but if you feed it rubbish , then rubbish you get .
A note : If you consider my frameserving idea , only frame serve (I think) 50,000 frames at a time , or the mpegs will blow past the 2 gig limit .
This I hope answers your question ...
As for creating the dvd project , go grab pgcedit now , its free , and I have a guide that explains how to use it to develope compilation dvds , and how to hook up menus and titles .
Prior to burning any dvd project , you should always play it back first to check for problems .
Why don't we have 128bit cpu's? OS issue? or do mulitcores make it obsolete
By yoda313 in forum ComputerReplies: 19Last Post: 9th Sep 2011, 14:16 -
How To Make Vegas Movie Studio Platinum 10 Use More % Of The CPU?
By JohnnyGalaga in forum EditingReplies: 18Last Post: 30th Jan 2011, 21:19 -
Is my computer powerful enough?
By T French in forum Newbie / General discussionsReplies: 8Last Post: 18th Apr 2010, 15:54 -
Building a super-powerful encoding station (or trying)
By Gargalash in forum ComputerReplies: 28Last Post: 20th Nov 2008, 11:22
