I use BeSweet to turn avi .wavs to ac3 files, then I try to run them through ac3fix, however after I use ac3fix on them and run them through winamp, it seems unbelievably butchered. Maybe ac3 files arent supposed to be run stand alone on winamp or like tmc? Because what happens is the entire file is like repeats of 4 second audio clips in the file. The clips change, but they always repeat and this is obviously not something I want along with my video. I'm not sure if I described that well but what happens, lets say the audio starts off with a guy who says "hello today how are you" it will go "hello today h" "hello today h" over and over. This has now happened with 4 different wavs from 4 different video sources but I couldn't find any record of this through the search which makes me wonder if its supposed to come out like that.
I found this command line app to work better than ac3fix.
http://vidphiles.com/AC3%20Cutter%20v0.1.zip
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 07:56 -
Aften vs Besweet vs Super vs AC3Fix vs working
By awesomer in forum AudioReplies: 2Last Post: 18th Nov 2007, 18:28
