I've done a search & looked through the posts but cant find any1 with a similar problem.
When i put a film thats divided into 3 svcd files into svcd2dvd it stops at the joins on my Sony player.
So, i used the merge & that worked perfect, it ran straight through, except the film then had no chapters.
So i did it again selecting chapters every 15 mins.
It only put chapters every 15 mins up until where the 1st join (from cd1 to cd2) is then it stopped playing.
Does svcd2dvd add the chapters before merging all 3 files ??
Any1 help out pls ??
Thanx.
Using 2.0 RC8
Hi there :¬)
FYI i reported this in thread called "More RC8 problems"
https://www.videohelp.com/forum/viewtopic.php?t=264932&start=0&postdays=0&postorder=asc&highlight=
CrissyBoy is aware of it -
It will be sorted for the next release.
Not necessarily. It is a combination of deducing the duration incorrectly (using pts or gop timestamps) and the fact that some key frames don't have pts values on certain encodings.
In RC 9 both issues should be resolved.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Kool.
How do i get RC9 to try ChrissyBoy ??
Is it only for the testers ?
Thanx..
merging files with mergemkv and retaining chapters
By lordhutt in forum EditingReplies: 4Last Post: 20th Feb 2012, 19:00 -
Problem merging 2 MKV's
By nutman in forum Video ConversionReplies: 3Last Post: 7th Dec 2010, 10:31 -
store video & also burn chapters according to datestamp (vista & dv
By Nicola-Pickle in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 08:08 -
Having Issues with Audio Sync when merging part 1 & 2
By DVDNewb in forum Newbie / General discussionsReplies: 8Last Post: 22nd Mar 2008, 03:00 -
Merging AVi's & including SRT's
By supersi in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2007, 10:40
