Hi,
I have the latest versions of the Nero Suite and have tried uninstalling / reinstalling (& used Nero Clean Tool) reinstalling DirectX but I still have the same issue where NVE now crashed if I either try to create a DVD (crashes at the point it starts to transcode the first AVI's) or even if I try to add a MPEG clip. It was working fine till I upgraded to the latest Version of Nero & installed the latest demo of Ulead Movie Factory (now uninstalled!).
I presume I have stuffed up a MPEG Codec - any ideas on how to fix would be greatly appreciated!
Nathan
Results 1 to 12 of 12
Worst case scenario: Backup all your valuable data. Format your system drive. Make a fresh OS install. Sometimes even faster than trying to fix the problem by chasing rouge codecs.
/Mats -
I have the exact same problem. I go to enode and it crashes giving me an error report to submit. This is driving me crazy. I need to figure this out soon. Anyone else experience this or better yet figured out a fix?
Well, there are other (and IMO much better) applications available for AVI (or anything else) to DVD...
/Mats -
If you are using NeroVision Express 3.1.0.0D, then there ia a patch (SMCpatch.exe) on the Nero website on the lower left of the screen.
I had a similar problem 3.1.0.0d but the patch fixed it.
good luckThe OldeMan -
http://ww2.nero.com/us/NVE3_patch.html
edit: i'm too slow... -
yes im having the same problem will have to try the patch, oddly enough i am running the same ultra and nerovision on my laptop as on my desktop laptop works fine desktop crashes
Originally Posted by Baldrick
Experienced a simliar problem except with certain DV material. Already patched NeroVisionExpress. Hope it works -
well i tried the patch and it did not work still crashes when i try to add files
Making video into timelapse, but adding frames
By oggologgo in forum EditingReplies: 7Last Post: 30th Dec 2010, 11:26 -
MPEG crashing Explorer
By T_Jet in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2009, 22:01 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 03:23
