    Sep 2004
    Hello, Im using Canopus Imaginate 2.0 & I have a project that Im trying to export. (project is 10min. long). When i go to render, my only option is to save as an avi. Then i get an error that the file is too big for this file type. Is there a way i can render to mpeg instead of avi? Or any other way to export the project? Thank You
    can't you select any compression when you select avi?
