Is it possible to record a winamp video stream (.nsv) using some program and save it as mpg, wmv, or whatever?
I used google,
Winamp Internet TV - NSV NullSoft Video. Play a Internet TV channel in Winamp.
The channel will be put in the Winamp Playlist.
Right click on that channel in the playlist and select File Info.
A URL will be listed there. Example: WeenTV
http://205.188.234.33:8030/;stream.nsv
These are SHOUTcast streams.
Use that URL in a SHOUTcast ripper.
Tested with.
RipCast.
StreamRipper32
StreamRipper Winamp Plugin.
It may also work in other SHOUTcast rippers as well.
If you use the Winamp Plugin it will also find that URL for you.
Some streams may need this User-Agent which you can set in the StreamRipper versions above.
WinampMPEG/5.0
SHOUTcast rippers think that all downloaded files are MP3 files so all files saved will have a .mp3 extension.
Since you know you are saving NSV (NullSoft Video) files you will have to rename the file after it is
downloaded to change the extension from .mp3 to .nsv.
Streamsave allows you to save videos with the .nsv extension.
http://p084.ezboard.com/fstreemeboxvcrfrm7.showMessage?topicID=12.topic
Recording an HD video stream
By bernardo-b in forum Video Streaming DownloadingReplies: 1Last Post: 26th Nov 2010, 12:14 -
Recording MMS stream from a certain point?
By Kanadon in forum Video Streaming DownloadingReplies: 4Last Post: 3rd Jun 2010, 22:31 -
Video Stream Recording Question (Looking for answers)
By likwid8 in forum Video Streaming DownloadingReplies: 2Last Post: 2nd Oct 2009, 11:58 -
Successful HD recording of Transport Stream.
By onerogueman in forum DVB / IPTVReplies: 0Last Post: 23rd Apr 2009, 21:06 -
Dreambox Stream Recording
By Max Wren in forum Video Streaming DownloadingReplies: 0Last Post: 1st Apr 2009, 10:28
