Getting my 1st mac and want to use it as a sorta portable movie player.
I normally use a PC w/ following codec files/packs
Divx 3.11
Divx 4
Divx 5
Xvid 1
Nimo Codec Pack
Tsunami
Vfapi
ffdshow
real alternative
I am trying to find mac install files for these or @ least the mac equivilant for each file
I am running MAC OSX 10.3 on a G3 600mhz ibook
Good choice, video is much more hassle free with Mac, you don't need really codec packs and therefore, nothing is going to be broken. Most codecs come with OS, for rest, check links...
Everything you really need (VLC):
www.videolan.org/vlc/
If you want encode:
www.3ivx.com/
For weird proprietary Micro$soft Windows Media stuff, use Media Player for OSX, from M$-site (per session links). Pretty bad piece of software, IMHO and mostly useless, if you use VLC..
And of course,
www.divx.com,
but 3ivx does actually much the same.i-NCO -
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Vlc does play xvid, but i still need the xvid codec installed for it to understand...do you know where I can get a mac version of the xvid codec.
Also Nimo is a just a pack of various codecs all bundled togethor so if you install it installs whole bunch of codecs -
VLC handles all decoding internally. It doesn't need installation of additional codecs, nor does it have support for it (in contrast with QuickTime).
As everyone keeps telling you, VLC will handle almost everything, and YOU DON'T NEED TO INSTALL ANY CODECS for it to work. Everything is built in.
MplayerOSX is an other player that will handle most anything you throw at it. Again, no additional codecs are needed. Everything is built in.
Now, if that's still not good enough for you, and you still have the need to install codecs, then Quicktime is for you. Install these 4 codecs, and you should be able to play most formats through Quicktime:
DivX
3ivX
AC3
Quicktime MPEG 2 Component
All of these are available at VersionTracker. The Quicktime MPEG 2 Component will cost you $19.95, but the other 3 are free. Good luck. -
well said, G13.
Urban Mac User
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
Help with finding video mixing software
By jackthedj94 in forum Software PlayingReplies: 8Last Post: 26th Jun 2009, 05:27 -
Help finding tripod for video camera.
By vid83 in forum Newbie / General discussionsReplies: 12Last Post: 21st Mar 2009, 17:31 -
Finding/Reading Video Format
By jkassen in forum MacReplies: 3Last Post: 16th May 2008, 08:37 -
can't play rm in mplayer on mac osx--did install reallib codecs
By onesuch in forum MacReplies: 2Last Post: 20th Dec 2007, 00:56
