I was wondering is it possible to reduce file size for mpeg 1 or avi? im trying to put 26 mpeg files in one dvd disc but doesnt fit.
so i was wondering if someone knows how to compress files or at least reduce their sizes. i usually exceed more than 4.7 gb.
so how can you compress or reduce avi or mpeg?
hi
As mentioned earlier change bitrate in TMPGenc to allow small file outputs. Secondly, dont forget DVD Shrink afterwards. Typically a 8.3/8.4gb file can just about compress to get onto a single dvd without a noticeable loss of quality-at least not that i could really see but i'm sure there is some.
End of the day, it depends on the quality of your source and the quality you want out at the other end-compress too much and it may end up looking like crap!
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 03:42 -
Reduce AVi file size
By froggger in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2009, 16:58 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 20:56 -
How can I reduce the file size of an XVID AVI without re-doing it?
By nic2k4 in forum Video ConversionReplies: 2Last Post: 20th May 2008, 14:05 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 09:32
