    Feb 2004
    Australia
    I was looking to something with a type of script and came across autoit3 the other week , and its free , and simple enough too learn .
    I made my first shell program with icons , buttons , tabs , ectra in less than 3 days , and included a help file .
    The second thing I did was :
    Newbies and others have asked about button creation , I assume for dvd , as I use it with pgcedit .
    So I am going to show you a script that adds 13 buttons to a single cell from a vob file .
    My intention is to write another script that will enable vobedit to rename all the cells Ids to 0 , 1 , 2 , 3 , and so on till last cell is located .
    Then have vobedit shuffle it out as cells , run a script to rename them as expected for ifoedit to create an ifo using the fisrt one and produce , say a movie preview vob was used , you will beable to have as many buttons where you like to have them now (36 being max) , cool stuff ...
    The script contains notes in places you should read to be sure , as this one has a slight goof (well I'm not perfect) , it took me 48 hours to get the mouse thing to work correctly .
    I will redo the script for users in a couple of days for 800 x 600 resolution , but for the moment its 1280x1024 ...
    Ps : dont post it anywhere else without asking me first , I am bjs in this forum and autoit's forum , i will find out sooner or later , and you'll be toast ...
    Without any more yabba yabba , heres the script , you will need to install autoit3 :
    http://www.autoitscript.com/autoit3/
    The script puts 13 buttons to the right and one on top of the other :
    Here it is people , enjoy :
    ; This script is for 1280 x 1124 screen resolution ONLY
    ; Only modify where I say you can do so ....
    ; This script is to automate the button creation within vob files
    ; Generated using Autoit Scite Autorecord
    ; Created through the knowledge of BJS in vobedit usage to create dvd menu buttons
    ; Script modified by BJS
    ; Original usage was for still menus ..
    ; But because of autoit , I have writen scripts to deal with movie menus that have audio streams in them ..
    ; For more info on BJS , web search for BJShotknowHOW.pdf ...
    ; It will include web site info soon , which will contain hundreds of scripts for newbies .
    ; You get to choose from screen resolution listings (not everybody has 17" or 32" monitor)
    ; Thats why I wrote that many ...
    ; Note : some programs used by these scripts do have a minimum screen resolution .
    ; Some programs can be adjusted internally to smaller scales , just like vobedit can .
    ; You agree that by using this script , you may not hold BJS liable for any coincidental
    ; pc damage , and that you fully understand it is YOUR responsibilty to check any scripts
    ; prior , as to there level of fitness before using them ....
    ; This mouse coords is giving me the S**TS....
    ; In some cases , if the mouse itself is not used to click on a certain boxs in vobedit , it will cause this script to do one of two things ...
    ; One : go plain spazz when error happens (safe , just gose plain stupid , bash the esc key repeatedly till it halts)
    ; Two : just plain stops
    ; This initial script took me 48 hours solid work to figure out what was acceptable betwwen autoit usage and vobedits allowed usages ...
    ; Drove me bonkers .........
    ; BUT IT DAMN WELL WORKS NOW ........... FINALLY ..... now to get some damn sleep
    ; next four lines is optional "opt"
    Opt("WinWaitDelay",100)
    Opt("WinTitleMatchMode",4)
    Opt("WinDetectHiddenText",1)
    Opt("MouseCoordMode",0)
    ; This line is NOT optional (the program MUST go there)
    Run('C:\Program Files\VobEdit.exe')
    WinWait("VobEdit","")
    If Not WinActive("VobEdit","") Then WinActivate("VobEdit","")
    WinWaitActive("VobEdit","")
    Send("{TAB 3}{ENTER}")
    WinWait("Open","")
    If Not WinActive("Open","") Then WinActivate("Open","")
    WinWaitActive("Open","")
    ; To do list
    ; Create script to generate 2 new folders - Vobmenu and Working
    ; Create script to allow user to choose vob
    ; Script - user is asked if allowed to copy , warned it must be or else (we keep original alone incase)
    ; Script runs ifoedit , ifoedit reads vob and renames all cells 1 to "?" , last found cell in vob
    ; Script ifoedit to split vob by cell id to working folder
    ; Script to rename original vob to Backup_vob.vob
    ; Script that will loop the next 2 lines till last know cell is done
    ; This vob menu script runs next
    ; Script to move updated cell to Vobmenu folder
    ; Script that renames all cells to VTS_01_???.VOB (the ? represents what order , ie it was 000 , then come 001 , and on till last known)
    ; Script that runs ifoedit , and joins cells in correct order into new vob called menu.vob , move to vobmenu folder
    ; Script deletes all old cell files from working folder , deletes backup_vob.vob , and deletes working folder only .
    ; Script - user asked to check final output of work , if happy with results , is asked to delete backup_vob.vob only
    ; Must include script to read number of cells found using vobedit , write to temp text file .
    ; This is to allow some scripts to do their work properly without stuffing up ....
    ; That should cover the damn thing .........
    ; This line needs modification to suit your needs
    Send("{TAB 7}{DOWN}{ENTER}")
    Send("{TAB 11}{DOWN}{TAB 7}{SPACE}{TAB 7}{DOWN 86}")
    ; Yes I counted the damn things as I pressed the keys
    MouseMove(511,89)
    MouseClick("left",511,89,2)
    WinWait("Edit value","")
    If Not WinActive("Edit value","") Then WinActivate("Edit value","")
    WinWaitActive("Edit value","")
    ; No idea ? , but it MUST be included
    Send("4096")
    ; Give me a break , even I dont know everything ..... yet , more info , web search for BJSdvdGUIDE.PDF
    MouseMove(232,48)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 61}")
    MouseMove(556,90)
    MouseClick("left",556,90,2)
    ; This number relates to the number of buttons you require for your menu
    ;XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXX
    Send("13{ENTER}")
    MouseMove(554,103)
    MouseClick("left",554,103,2)
    ; This number realtes to the number of buttons you require for your menu
    Send("13{ENTER}")
    Send("{DOWN 61}")
    MouseMove(555,89)
    MouseClick("left",555,89,2)
    WinWait("Dialog","")
    If Not WinActive("Dialog","") Then WinActivate("Dialog","")
    WinWaitActive("Dialog","")
    ; Important : both numbers realeted to number of buttons MUST be the same
    ; and relate to the button information I have supplied for all thirteen buttons
    ; You may replace the following code for your own color scheme , if you know what you are doing first
    Send("{TAB 2}00005af011105af0")
    MouseMove(482,52)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 72}")
    MouseMove(549,89)
    MouseClick("left",549,89,2)
    Send("{TAB 2}22205af033305af0")
    MouseMove(474,51)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 72}")
    MouseMove(598,90)
    MouseClick("left",598,90,2)
    Send("{TAB 2}44405af055505af0")
    MouseMove(475,50)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    ; Now we do the buttons , in this sample there are 13 , they stack on top of each other over to the right ....
    ; As this is for 1280 x 1024 screen resolution , under NO circumstances , and I mean it ..... the following
    ; DO NOT CHANGE SENDS , these are accurate for 1280 x 1024
    ; You may change numbers where I say so only , thats the rule , break them , and the script fails .... you have been warned
    Send("{DOWN 74}")
    MouseMove(557,86)
    MouseClick("left",557,86,2)
    ; These numbers below may be changed - you must know what you are doing FIRST (ask bjs in autoit forum for pdf that explains it all (300kbs in zip)
    Send("{TAB 2}1{TAB 2}535{TAB}40{TAB}614{TAB}62{TAB}13{TAB}2{TAB}1{TAB }1{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; These numbers below may be changed (they relate to how they connect to components in dvd structure (titles / other menu's)
    ; As there are 13 buttons in this example , they should relate to different titles / menu's
    ; This one plays first title (say spiderman preview)
    Send("{TAB 2}300200000001")
    MouseMove(470,49)
    MouseDown("left")
    MouseUp("left")
    sleep(1000)
    ; Need to realign appropriately according to rest of script ....
    send("{DOWN 56}")
    MouseMove(557,86)
    Send("{TAB 2}1{TAB 2}535{TAB}85{TAB}624{TAB}108{TAB}1{TAB}3{TAB}2{TAB }2{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays second title (happy gilmore preview)
    Send("{TAB 2}300200000002")
    MouseMove(470,49)
    MouseDown("left")
    MouseUp("left")
    sleep(1000)
    WinWait("[removeme]VobEdit[removeme]","")
    If Not WinActive("[removeme]VobEdit[removeme]","") Then WinActivate("[removeme]VobEdit[removeme]","")
    WinWaitActive("[removeme]VobEdit[removeme]","")
    Send("{DOWN 56}")
    MouseMove(598,86)
    MouseClick("left",598,86,2)
    Send("{TAB 2}1{TAB 2}535{TAB}126{TAB}648{TAB}152{TAB}2{TAB}4{TAB}3{TA B}3{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays third title (sharktale preview)
    Send("{TAB 2}300200000003")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}170{TAB}660{TAB}194{TAB}5{TAB}5{TAB}4{TA B}4{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays forth title (pitchblack preview)
    Send("{TAB 2}300200000004")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}208{TAB}670{TAB}236{TAB}4{TAB}6{TAB}5{TA B}5{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays fifth title (sharks bay preview)
    Send("{TAB 2}300200000005")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}248{TAB}650{TAB}274{TAB}5{TAB}7{TAB}6{TA B}6{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays sixth title (blue beard preview)
    Send("{TAB 2}300200000006")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}290{TAB}668{TAB}316{TAB}6{TAB}8{TAB}7{TA B}7{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays seventh title (Track gore - mini movie I made) , truck racing claims innocent by stander behind safety barrier , rated 18+
    Send("{TAB 2}300200000007")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}328{TAB}698{TAB}354{TAB}7{TAB}9{TAB}8{TA B}8{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays Eighth title (bear cavern preview)
    Send("{TAB 2}300200000008")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}370{TAB}664{TAB}396{TAB}8{TAB}10{TAB}9{T AB}9{TAB}{ENTER}")
    If Not WinActive("[removeme]VobEdit[removeme]","") Then WinActivate("VobEdit","")
    Send("{DOWN 66}")
    ; This one plays nineth title (socom game preview converted)
    Send("{TAB 2}300200000009")
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}406{TAB}638{TAB}432{TAB}9{TAB}11{TAB}10{ TAB}10{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; ok , from here on it gets a little tricky so I will include the code for my 13 buttons
    ; 13th points to another menu ...
    ; to understand alot more about these numbers , you should grab bjs_pcgedit_guide.pdf , which explains alot and how to get past pcgedits button creation problem .
    ; when you save your dvd , they dont exist , this is WHAT this script FIXES .....
    ; ATLEAST SOMEONE OUT THERE HAS AN ORIGINAL IDEA , and is thinking of ways to get around programs and their inabilities .
    ; This is to assist newbies into dvd creation , fast yet flexible , and with full support from bjs on any of his scripts
    ; Just pm bjs at autoit forum , and me will reply (BJS is ME) ...
    ; ok , lets look at these double digit title numbers now ....
    ; This one plays tenth title (battlefield earth preview)
    Send("{TAB 2}30020000000A")
    ; Notice that A , yes , it represents 10th title
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}448{TAB}638{TAB}474{TAB}10{TAB}12{TAB}11 {TAB}11{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays eleventh title (evil dead 2 preview)
    Send("{TAB 2}30020000000B")
    ; B is for 11
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}486{TAB}674{TAB}516{TAB}11{TAB}13{TAB}12 {TAB}12{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; This one plays twelfth title (carmagedon preview)
    Send("{TAB 2}30020000000C")
    ; this one is C
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    Send("{DOWN 56}")
    MouseMove(598,86)
    Send("{TAB 2}1{TAB 2}535{TAB}528{TAB}622{TAB}554{TAB}12{TAB}1{TAB}13{ TAB}13{TAB}{ENTER}")
    Send("{DOWN 66}")
    ; Lucky for some I think , but for now , it links to the second menu called PC GAME PREVIEW
    ; it is a title you bring into [removeme]pgcedit[removeme] , then scan for bov's , then link the buttons up to what you need
    ; of course I have already told vobedit the titles each points to .
    Send("{TAB 2}30020000000D")
    ; Wait till you get to having 55+ titles , it changes dramatically
    MouseMove(474,49)
    MouseDown("left")
    MouseUp("left")
    Sleep(1000)
    ; dont know this yet , but when done the scipt ends , get out .
    ; leaves vobedit open for you to judge what has taken place , if happy , close it
    ; thats that .....
    ; hell no , it works , so why do it any other way , maybe I will add the end to it , later ............
    ; These are the three color schemes used
    ; My color schemes
    ;Send("{TAB}{TAB}00005af011105af")
    ;Send("{TAB}{TAB}22205af033305af")
    ;Send("{TAB}{TAB}44405af055505af")
    ; Here I have a list of buttons you can have (36 is maximum allowed) , and broken into groups for this example
    ; Pay attension to notes , and you wont go wrong
    ; 13 buttons with correct numbers already created to go into application
    ; My example buttons for menu only
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}40{TAB}614{TAB }62{TAB}13{TAB}2{TAB}1{TAB}1{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}85{TAB}624{TAB }108{TAB}1{TAB}3{TAB}2{TAB}2{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}126{TAB}648{TA B}152{TAB}2{TAB}4{TAB}3{TAB}3{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}170{TAB}660{TA B}194{TAB}5{TAB}5{TAB}4{TAB}4{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}208{TAB}670{TA B}236{TAB}4{TAB}6{TAB}5{TAB}5{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}258{TAB}650{TA B}274{TAB}5{TAB}7{TAB}6{TAB}6{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}290{TAB}668{TA B}316{TAB}6{TAB}8{TAB}7{TAB}7{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}328{TAB}698{TA B}354{TAB}7{TAB}9{TAB}8{TAB}8{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}370{TAB}664{TA B}396{TAB}8{TAB}10{TAB}9{TAB}9{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}406{TAB}638{TA B}432{TAB}9{TAB}11{TAB}10{TAB}10{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}448{TAB}638{TA B}474{TAB}10{TAB}12{TAB}11{TAB}11{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}486{TAB}674{TA B}516{TAB}11{TAB}13{TAB}12{TAB}12{TAB}{ENTER}")
    ;Send("{TAB}{TAB}1{TAB}{TAB}535{TAB}528{TAB}622{TA B}554{TAB}12{TAB}1{TAB}13{TAB}13{TAB}{ENTER}")
    ; Another 22 buttons
    ; Last button you can have ...(36th)
    ; Always include 1 button that can return to previous menu , if you dont , your silly ...
    ; Final Notes :
    ; I have created a guide to show how to create motion buttons for your dvd menus using vitualdub and avisynth
    ; I am also currently working on scripts that help automate this work .
    ; Takes time to write guides that even NEWBIES can understand from scratch ...
    ; Maybe , some other people out there might CONSIDER updating their products help file to reflect this .
    ; Supplying samples is one thing , they need to have a minimum of 6 ways of using that information ...
    ; Most people learn from actually seeing it work , then ask how it works , only then will they beable to learn ...
    END ....
    And a pic of the outcome is nice , sorry for the lower quality ...
    Yep another goof , but in the end its the same thing ?
    Feb 2004
    Australia
    Opps , watch out for that damn smiley , its about halfway down in my script (should have turned off - automatic tool link thing)
    As for the pic not being here , well thats just xp being its same old useless self again ...
    Autoit can automate many tasks that would otherwise take a long time to do manually , and its free unlike that lame macro recorder rubbish ...
    What can it do for you ?
    Anything you need , and works in winxp / winme / win98&se
    Now that I have it myself , it saves me hundreds of hours when creating flashy dvd menu's .
    When I mean hundreds of hours , I mean the following :
    1: vobedit - rename all cell id's from 1 (first) too ? (last cell found)
    2: Vobedit - demux by cell id to new folder
    3: Autoit - run vobedit , and add all information to each cell (button info)
    4: Autoit - rename all cells to requirements for ifoedit create ifo
    5: Ifoedit - create ifo , add first cell , and put all into new single vob file
    Done , new flashy menu is finished .
    6: autoit script deletes all cells left over from project (vob left)
    7: autoit runs pgcedit , loads that vob (open dvd)
    8: Autoit loads all titles (imports) (copys vob titles - to folder)
    9: Autoit deletes menu (dummies - there a right pain)
    10: Autoit imports more titles (I passed that lame no more ? avail prob)
    11: Autoit now places all commands required to connect menu / titles
    12: Autoit saves dvd
    13: Autoit now calls dvd player software , loads new dvd
    14: autoit watches for dvd app closure ...
    You check it out before burning it of course ...
    15: Autoit now asks if it was fine (ok to burn this dvd , yes / no)
    17: If no , gose back to pgcedit (you manually need to fixup problems)
    18: Once fixed , run script called "continuedvdburn"
    19: Plays dvd again
    20: Watches for app closure .
    21: Yes / no . if no , goto 17 , if yes , goto 22
    22: Puts box on screen (continue) , spits drive tray open
    You click ok to continue once drive stops spinning about
    23: Autoit calls imagetools , loads dvd files , sets burning defaults
    24: Autoit pops box up
    "Close all running tasks you do not need now before you click Burn button"
    25: Closing that box says burn dvd
    Smileys all about , enjoy yur new dvd compilation
    Takes a few script to do all this , I am currently working on one script that can make the required calls to run the others , and back again .
    Shell app 80% complete , so newbies can select there own personal vob file , where the project folder is to be created , add there own button placement requirements , and choose there dvd player software they have .
    It will detect if require apps are in the correct place , most just go into program files folder .
    that's it , if you have ifoedit , vobedit , imagetools , and a dvd player software package already , thats all you need .
    Crazy as it seems . but why do people keep telling newbies to buy useless products , when given a little information , it can all be done for free ????
    Just finished my newbies guide on pgcedit and how to make a compilation dvd , available shortly , my friens have to beable to follow the guide .
    If any have a problem , thats where the guide may get an update so they can understand it ...
    Its to be newbie bullet proof prior too any upload ....
    Yes , I am a man on a mission .
    1: To help newbies out
    2: Destroy all others
    3: Maybe take over the planet someday ....lol
    Feb 2004
    Australia
    Did I forget to mention you also need pgcedit ..... coffee time
    The app will also mention other freeware dvd software , and the links to there appropriate sites
    So if no dvd player software is available , you can choose one to download , the free dvd codec download is part of this of this script as well ...
    Not bad considering I have had autoit for around 3 weeks ...
    Very easy to learn and program ....
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    So what's all this about then ?
    If in doubt, Google it.
    Feb 2004
    Australia
    Just all about programing .
    Did you ever want to automate something you do on the pc that take's time you rather be doing something else ?
    Well now you can , and its easy with the new autoit recorder , it tracks every key press and mouse click as you go .
    And you can combine it with task manager to launch and run the task you require , like go online , finish downloads , check mail , do all you web searches for you , oh , and how about annoying friends with an automated message in yahoo , that makes no sence , they think there chatting to you , and it takes them a few minutes to realize no ones home , very funny and annoying .
    Ok the bottom line :
    Lets say you have 50 x 200 mb video files that need to re-encoded .
    You have 2 folders , one contains all video files , the other is for processed files , right , you with me .
    You could write a simple script that takes the very first file , and transcodes it to the other folder , then it automatically moves the raw file to the recycle bin as a safe backup .
    When the last one is done , and job is over , the whole process stops .
    Mean time , you have been out socializing with friends , walking the dog , kicking the cat about , or teaching the budgie to swear like a trooper ...lol
    Thats what its all about , and it can do more , some users are using it for playing games so they dont have to keep hitting the mouse button to fire , dont ask me that one , I have more important things to do .
    For me it means dvd creation is simple , but I do have to give it the same number of files , unles I change a portion of the script before hand .
    So far I have managed to hookup :
    Pgcedit : create dvd , open dvd , import titles , delete the dummy menu when the error box happens , imports my menu , scans for bovs , and saves it , then I come back later and hook all the buttons up to their respective titles and menus .
    Vobedit : button information into still vob menu's
    Pgcdemux : automatic demuxing of all vobs from 1 folder to another , the script also renames the files as it gose so none are over writen .
    Ifoedit : create new ifo , locates video and audio streams and outputs to a folder , and renames them to prevent being over writen .
    Besweet : tough sod this one , took me some time to figure all the required hooks , converts all audio too 5.1 ac3 format .
    Avisynth : the automation of loading a particular script in vitualdub for frameserving to bbmpeg , dose my motion menus with motion buttons , and renames the files 0 to ? last .
    Menmodder : to load video , then the button video (same file) , but works so I can see the button layout .
    Dvdauthorgui : the works for more simpler projects .
    Run system wide utilities , such as defrag , and the automation of burning one particular backup folder to cd / dvd , prior to pc shutdown .
    As you can see , it gives you back more time to do another things .
    I simply have 6 folders , and all the scripts relate to those folders only , so its a matter of placing audio in one , video into another , and fire off the script to perform all the tasks .
    At the end of all that , I have a dvd thats ready to be played .
    How cool is that , and autoit is simple to learn , and you can cheat by using autoitrecorder to follow you about to create your scripts .
    I've made a shell for my scripts , looks like another program , I just choose which one I want the pc to do , and let it rip .
    Oh forgot one .
    Smartripper automation , then dvdshrink , then imagetools , nice ..
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    So it's basically a macro-recorder then ?
    I was just interested to know why you'd dump a 744 line script in here in raw text, as opposed to just uploading the script file and linking to it, that's all ...
    I use MacroMagic for this sort of thing.
    (BTW, I'm a programmer by trade and education, so no need to dumb it down too much )
    Feb 2004
    Australia
    Cant be done right now , my xp is stuffing about , and I been putting the clean reinstall off till my puchase orders come through so they can be backed up .
    I tried to upload , and the post appeared , but the file attachment didnt , i tried 4 times and game up on that idea .
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Upload the file, then edit your post and put [*url]filename.ext[/url] (without the *) and it should work.
