Hey all, my friend gave me a dvd movie that he made and it has a sex scene that I wanna take out.
How would I go about this? Would I have to rip the audio to mpeg2 audio so that I can edit the video and the audio together? because it's dolby 5.1 right now and I would like to leave it as dolby 5.1 if possible. Please give me the steps or direct me to a guide. I don't know how to rip from dvd to mpeg2 (or whatever i should rip it to) either...
Thanks for helping out a newbie.
Results 1 to 30 of 33
Rip it, edit in MPEG software. Reauthor.
You could do a quick & crude chop with DVD Shrink.
Just Re-author the main title, using the Set Start/End Frames feature. You'll have two titles & the transition won't be perfectly seamless, but it's quick & easy (and free).If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Your friend "made" a movie with a sex scene in it? Is it a home movie? Interesting. Deviant, but interesting.
There are several guides to the left to help you in this situation. If you search around you can find this info also. Possibly be aware that you may get flamed for wanting to censor something... Not a good subject to bring up. -
Yeah I figuredOriginally Posted by smearbrick1
Anyway, I'm looking at a dvd shrink reauthor guide and I am now seeing that I have to drag the right files to the left side of the screen which is the "Re-authored dvd" side.
Do I only drag the main movie over? If I dragged everything over (menu, chapter menu, extras) over would it still work right? I figure if i cut something out it might mess up the other stuff. Maybe not though. Help!
DVD LabPro will let you "cut" out scenes by highlighing the start/end sections you don't want included. The original mpeg stays asis, but when the movie gets to the start point, it jumps immediately to the end point of your "cut" scene. Since the mpeg is never actually cut, video/audio sync shouldn't suffer any...
Keep in mind that a smart viewer would be able to rewind backwards to the "deleted" scene (if they knew it was there).George -
Drag only the main movie.
(If you were to drag "everything" over, the menus would not function correctly. They retain functionality only in Full Disc mode.)
Use the Start/End Frames feature to set the end frame to the moment before nudity.
Drag over the main movie again (below the first one you just trimmed).
Now use the Start/End Frames feature to set the start frame to the moment after nudity.
You should now have two titles which should play in succession.If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
so your trying to censor a copy,an illegal copy you shouldnt own.if its got a sex scene then its been rated not for children.dont let them watch it,and go get a life,these dvd editor topics piss me right off.
LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
interesting thread...
if it wasn't for a couple of scenes in Titanic, I would let my 13-year old watch it...George -
A company called ClearPlay either has, or shortly will have a dvd player that will do that automatically for you.
Maybe not for now, but in the future if your children are still young.
I've never condoned censorship, but hey just about ever tv station (as well as some cable/sat channels) have done it for ages, so why cant you?!
Kudos for asking the question, maybe it'll teach some of those stuffy hardliners out there that, (ahem, they have the right to backup their video blah blah blah, but feel that editing is wronging the makers.) If ya have the power to back, edit etc it should somewhat be your descreation (SP!) how its used in YOUR household...to an extent of course..
Sabrowww.sabronet.com - It's all you need...to know -
Now, now...don't jump to conclusions....he never said it was a copywrited movie....Originally Posted by RottenFoxBreath
Just said a friend made him a movie....could be a vaction or somethin'....
Although it sounds like a really GOOD vacation
Bob T. -
Originally Posted by GeorgeW
when the boat sank and 1000's of people died ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
no, no, no, when the old lady threw that priceless necklace back into the sea -- I almost cried
George -
yea -- i might have chopped that out also ...
If you have TDA, just import the video into a project, then edit out the scene(s) there. TDA has an excellent editor (cutter).
I have successfully made the backup using your method. Thanks.Originally Posted by Shocker Milwaukee
One question though. When im on the first half of the movie (title 1) i can't jump to title 2. I just have to wait for it to move on with normal play. Once it get's to the 2nd half of the movie (title 2) I can't seem to rewind back to the first half (title 1). It's no biggie, but it would be nice to be able to.
There is a title button on my sony controller (I have an old sony dvd player) but nothing worked.
Do you know how to jump between titles? -
My Sony DVD player has a button called 'search mode' that triggers a title # screen. There I can push up (arrow) or down (arrow) to navigate between titles. You also might be able to just use numbers, like pushing 1 or 2.
George Carlin -
Going on how important it was for you to save the 5.1, Maybe try VirtualDubMpeg. You can save the scenes you want and those you dont; then 'append' together afterwards. Then drop into VirtualDubMod, extract audio to retain 5.1. TDA will encode at best to 2ch AC3 i believe. The above 2 programs are freeware also. Once done then just remux & reauthor and burn off.
You could just be a good parent and not let your kids watch that illegally pirated R-rated film.
But no, you want to waste hours of your life in the pursuit of a solution you can never really get properly.
And in the end, your kids will be fucked up beyond belief. Go on, people have been ******* up their kids for generations. -
Originally Posted by Gurm
The cheapest/fastest/best solution is to instruct your kids to shut their eyes and cover their ears during said scenes
But seriously, yeah you can cut the scene out, but if you want to retain all menus and extras as well, I think you'll have a battle on your hands. Off the top, you could probably keep all the extras if you re-author using TMPGEnc DVD Author, but you'd probably have to make your own menu for it.If in doubt, Google it. -
Gurm,you always bring a smile to my face.pmsl.
For Titanic surely you would want to cut the part between the start and end credits?
When I was little, my mom put here hands in front of my eyes, and/or told me to cover my ears. She probably would have used the MUTE button, had one existed back then.Originally Posted by jimmalenko
I remember a comment left by somebody in a thread like this long ago. It was amusing, so I'd like to repeat (paraphrase): "Can you tell me how to do this too! I want to remove everything but the fighting and sex scenes" :PWant my help? Ask here! (not via PM!)
Covering your eyes doesn't work!!!
I remember seeing Jaws in the theater when I was 5 and I knew something bad was going to happen when Hooper when in the water. So I covered my eyes and when it sounded like nothing was happening, the head came out of the hole in the boat!!!! Scarred for Life!!! :P
There's something wrong with a society when it's more accepted to show 2 people punching their faces out, but not showing 2 people in love. Unless you're showing them Basic Instinct, then that's just wrong...kinky, but wrong :P"*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda -
its kind of interesting that people think movies have that much of an effect on children.. its like trying to get pee out of a swimming pool, you can try as hard as you want, but its just not gonna happen.. if your kids becomes a sex maniac from watching a movie with nudity, or a serial killer from watching a violent movie then i seriously doubt it was the movie that caused that to happen to him/her.. there had to be something going on in their life that caused it, probably caused by bad parenting..
I want to take out the sex scenes from some kiddie porn... also some violent scenes in some snuff flicks... How do I do that please?
MORON!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! -
Interesting that people always want to censor sex but never violence. You can kill hundreds of people in a film and no one complains, but let two people make love and the world is up in arms.
Man people are stupid.
How many children do you have?
By johns0 in forum PollsReplies: 13Last Post: 25th Oct 2010, 13:29 -
VHS-->DVD, "action scenes" and bad sources
By Jdrive in forum Capturing and VCRReplies: 7Last Post: 13th Oct 2010, 01:09 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Is there anything wrong with adults watching children's TV?
By Jumbo_Holden in forum Off topicReplies: 63Last Post: 22nd Dec 2008, 20:05 -
turning children's TV episode into a read-along story
By sallam in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2007, 21:03
