I've looked everywhere but can't find a DV capture program that outputs the number of dropped frames after a capture. For me, this is a critical issue because I like to use my computer while I am capturing a 2 hour tape and I need to know if there was a moment when frames were dropped due to the computer being used by something else.
I had a program that did this but I can't remember the name of it....
I tried Exsate but there were times when it dropped frames but told me it didn't. So I am looking for something that works.
I downloaded the program, but can't see where it tells you how many frames have dropped.Originally Posted by compuser
It is on the bottom info bar, it is only visable when capturing...
Another option is Scenalyzer. In addition to counting dropped frames, it also lets gives you the option to "stop recording" in the event that frames are dropped. Although not freeware, it has lots of other great features that I have found extremely useful.
wwaag
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 16:00 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Pleas Help with intensity pro capture dropped frames issue
By jub2k3 in forum Capturing and VCRReplies: 14Last Post: 18th Jun 2010, 13:38 -
Pryo DV capture adds tons of blank frames in between dropped ones.
By Knightmessenger in forum Capturing and VCRReplies: 11Last Post: 18th Jul 2009, 17:08 -
Neither Vegas Video nor WinDV show dropped frames count after capture
By korey99 in forum Capturing and VCRReplies: 13Last Post: 9th Apr 2009, 17:25
