  1. Banned
    Dec 2003
    Will someone go Here to see if they are able to use and view videos at yahoo music.
    When I try to use the service, it just gets hung. When I try to paste the url in WMP9, I get "ClassFactory cannot supply requested class" Can anyone help?
    PS If you are not a yahoo member, you might have to register.
  2. I just did, it works fine.
    Maybe you should try to clean your internet files, and check for spyware. When you first start to use Yahoo Music, it downloads a small console so you can listen to music and watch videos, maybe it's corrupted and that's why you can't use it anymore.
    If you clean the IE cache, and erase all downloaded files from the directory, It will reinstall itself the next time you enter the site and you will be able to use it again.
    Let me know if it worked.
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  3. Banned
    Dec 2003
    After cleaning IE temp file folder, I get to the media player configuration. It says If I can see the video clip Click here, but the video never plays
  4. I have no idea then... have tou tried changing your browser?
    What browser are you using?, also, what is your intenet connection?
  5. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Maybe the switched to WMP10? just a thought but I doubt it.
  6. Banned
    Dec 2003
    IE 6. DSL 1.5Mbps. I could at one time, but I don't know what happend.
    And you guys are able to watch videos?
  7. I am, it works ok for me. Still having the problem?, are you using Windows Media Player 10?
