Page 3 of 3
FirstFirst 1 2 3
Results 61 to 63 of 63
  1. Originally Posted by akrako1
    under the 'Video' tab, theres an 'Encode Mode' option. It's currently set to 'Interlace'. The other options are 'Non-Interlace' and 'Inverse 3:2 pulldown'. Any ideas which one to use?
    Encode Mode should be set to "3:2 pulldown when playback". This will force the DVD player to perform a 3:2 pulldown when it plays the video to your TV (to make 29.97 fps). A few lines above that, Frame Rate, should be set to "23.976 fps (internally 29.97 fps)".
    Feb 2003
    Well... after alot of headache, I've given up. Each episode that I'm trying to de-interlace seems to have frame inconsistencies at nearly every break (commercial interruptions, title sequence, etc), and it's too big of a pita to take up my time. Maybe at some point, I'll try de-interlacing a whole movie (hopefully no inconsistencies), and I'll try and use these suggestions. Thanks!
    If only there was a program or filter that could recognize interlaced frames and automatically correct the sequences.... ahh to dream...
  3. Originally Posted by akrako1
    FieldDeinterlace plugin for avisynth has such abilities AFAIK.
    Edit: for recognition of interlaced frames I mean (it check the frame and deinterlace only if it is interlaced), not for correction of the sequences
    Edit2: Ah, this is not a separate plugin, sorry, this is a function of decomb plugin.
