I have a Satellite receiver that has an external hard drive connected to it. I have tried to get Windows to recognise the file that it makes, so that I can make a DVD of what I have recorded.
The receiver is a Manhattan plaza st 550. After making a recording onto the hard drive, I take the hard drive to the computer and connect it as the secondary master, which can be read from the primary master.
I then try to read what is on it from the other hard drive on my computer. It does say that there is a media file on it, but does not recognise it as a windows file.
Widows explorer cannot read the file, so I am unable to read the file extension. I did try and have Windows on the drive before I connect it to the receiver, but it would not accept that at all. Can anyone tell me please, should I be able to read the file or convert it to mpeg using some extra software, or is there another way I have not tried yet.
Regards, Bobby.
Don't know answer to your specific question, but here's a link to a forum which gives a link to a yahoo forum on doing this very thing with a dish network receiver. Haven't tried it myself. It may give you an idea of how to proceed with your receiver / hard drive.
http://forum.cdfreaks.com/showthread.php?t=63373&highlight=dish+network/ -
Thankyou both for your reply, i have joined the Yahoo group and have posted the same questune. I am also downloading the the program you suggested to have a look at what it can do. Not quite sure what Demux is though.
Regards Bobby. -
try to extract the files using DVR studio
http://www.haenlein-software.de/haenlein-software/index2.php?navigation=dvr-studio&una...prache=englishLa Linea by Osvaldo Cavandoli
Thankyou SatStorm, i think you are on the right lines there. I need to study the program a bit first, but it looks promising.
Regards. Bobby.
HDD recorder for satellite receiver
By Bazza11 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 18th Aug 2011, 14:17 -
Is there any way of getting 5.1 to my receiver from my computer?
By maxone71 in forum Software PlayingReplies: 5Last Post: 7th Jul 2011, 19:14 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / IPTVReplies: 1Last Post: 19th May 2011, 05:38 -
Computer to stereo receiver - no sound
By dadrab in forum ComputerReplies: 4Last Post: 23rd Apr 2008, 13:56 -
How to capture video from satellite receiver's DVR two shows at a time?
By theinv in forum Capturing and VCRReplies: 7Last Post: 16th May 2007, 10:23
