In the TMPGEnc wizard, it can show you what the projected file size of a converted mpg file will be, before you even convert it. If you slide the size scale to make it a smaller amount of Megabytes, the video kbps will be adjusted accordingly.
I am looking to do something similiar, but for AVIs. I want to convert divx movies to a smaller size so they can fit on my pocket pc. Please tell me a program of give me any info that you might think will be helpful to what i am looking to do.
try dr. divx or Pocket DVD Wizard or Pocket DVD-Studio or PocketDivXEncoder or learn how to use virtualdub and config the video bitrate manually.
Are all advertized low profile pci cards under a specific size?
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2010, 11:19 -
After riping DVD to hard drive, how do I *acurately* to specific XviD size
By Thomas Davie in forum MacReplies: 8Last Post: 23rd Sep 2009, 13:13 -
Compressing to a specific file size?
By toxicquack in forum MacReplies: 6Last Post: 17th Oct 2008, 21:04 -
specific file size
By santino_avi in forum Video ConversionReplies: 4Last Post: 14th Jan 2008, 00:04 -
batch convert avis to cd size
By clawg in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 12:27
