I have a Philips maganvox 825DVD player. No matter which options I use when I burn a vcd or svcd I get no sound when trying to play it on my dvd player. It plays fine on my computer.
Any help would be greatly appreciated.
I have the latest firmware too.
Silly question but... Is there sound when you play it on your computer..?
_________________
Magnus Jensen
A.K.A Geezus
<font size=-1>[ This Message was edited by: KuskenLars on 2001-12-13 00:46:13 ]</font> -
have you tried both audio outputs alalog and digital ? my magnovox 841 will only play svcd's (audio) throught the analog outputs. vcd's play fine either way.
I have 2 philips dvd-players, and they do very well play vcd-sound thorugh digital out. The only drawback is, that the stream is MPEG-encoded, and most surround-amplifiers do not decode mpeg-audio, only PCM, AC3 and DTS. So use the analog out for any vcd-sound or reconfigure (not recommended) the digital out to "pcm only". it's poor that you cannot choose the output format for the major stream types separately. This is a flaw of most dvd-players.
It does play sound on my computer, and in a friends dvd player other vcd's I've tried to make play fine. I tried both the digital and analog outputs, but I'll try the analog again to make sure.
I noticed that when I pushed the audio button on the dvd remote with one svcd it had audio 0 in the little box that came up, and another audio 1 (2 diff svcd's), but no sound.
Did you split the file with mpeg tools in tmpgenc? If you don't specify splitting it into a vcd when using the mpeg tools, mpeg system is the default, and it won't play audio properly on the 825.
407 -
Is till get no sound from the vcd's through normal methods but . . .
I was playing around, and If I plug headphones into the headphone jack, I get sound. So i ran a line from the headph0one jack to the stereo, and now I have sound for my VCD's
Maybe this will help someone else.
Which is better, Phillips or Magnavox BD-R?
By jbitakis in forum Blu-ray RippingReplies: 2Last Post: 18th Nov 2011, 15:35 -
Sound distortion when play CD on Magnavox ZV457MG9A
By AliceWonder in forum AudioReplies: 1Last Post: 12th May 2011, 12:16 -
JVC HRJ-825 PAL VCR - what is it like?
By Quasipal in forum RestorationReplies: 3Last Post: 11th Jan 2011, 04:49 -
Phillips DVP5990/F7 and .AVI - video is Ok, but no sound
By PaulGor in forum DVD & Blu-ray PlayersReplies: 10Last Post: 16th Apr 2010, 13:12 -
Phillips 5982 - Which receiver inputs for sound when using HDMI ?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 19Last Post: 13th Dec 2007, 17:45
