I have caputred several MPG video segments using the DVD-quality setting on my Hauppauge WINTV-PVR250 card. I am now trying to burn them to DVD, but I always have issues with compatability. It will play in my main standalone player, but with no sound. My secondary player will play it half the time but not the other hald. PowerDVD says "unsupported disc format in drive f:". Ulead DVD Player plays it fine. Windows Media Player plays the video with no sound. My friend's standalone player plays it fine. I have tried burning this DVD with Roxio EasyDVD Creator, TMPGEnc DVD Author (no AC3), NeroVision Express, and Ulead Easy Disc Creator, All of which have very similar outcomes in terms of compatability. I have an Asus 16x burner, and am using Legacy 8X DVD+R discs, which I have heard are fairly good. Would adding the AC3 plugin to TMPGEnc DVD Author fix this? Or am I just doing something wrong? Thanks for any help.
Some dvd players have problem with mpa/mp2 audio(wintv capture to this) or you might have to change the audio settings in the dvd player to mpeg layer 2 -> pcm or similiar. If you get the ac3 plugin for tmpgenc dvd author you should get sound.
And be sure to use GOOOD media. -
Ok, if I don't want to pay the $29 for the AC3 plugin for tmpgenc dvd author, is there a free tool I can use to extract the audio from my mpg files and convert it to AC3?
ok i just went ahead and bought the AC3 encoder...seems to work in every software player i have now, but i will have to wait until i get home next week to see if it works in the other standalone players. thanks for your help.
Common Codecs and xVid / DivX compatability
By anonymous_whatever in forum Newbie / General discussionsReplies: 25Last Post: 20th Feb 2012, 18:53 -
Sony WEGA KE-42M1 Compatability with Panasonic Blue Ray
By Worlcup in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Dec 2011, 00:14 -
Video Playback, File Compatability
By TomFriedmann in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2011, 09:14 -
Sony Z7 compatability
By 392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Nov 2009, 23:06 -
Compatability of DVD+R DL media with LG LDA-831??
By jamiemark in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Mar 2008, 11:07
