I joined 2 wmv files then converted the joined file to MPEG1 using TMPGEnc. I used SVCD2DVD to author & burn the mpg file to DVD.The resulting output files looked fine but the DVD would not play on my DVD player although the VOB file would play on my PC.
Using exactly the same method I used Nero to author & burn the DVD. It played without problem on my DVD player.
Any comments would be appreciated.
What are the details of the mpeg1 files?
The size is not compatable with the DVD specs. It would need to be 352 x 288 for PAL or 352 x 240 for NTSC to be compatable (i.e that is the closest to your source resolution).Originally Posted by prn6243
I suspect Nero is resizing to one of those & that is why it plays ok. If you had converted from wmv to mpeg1 and resized at the same time in TMPGEnc then there would not have been an issue with SVCD2DVD.
Does that make sense?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yes it does. I will re-convert to 352x288 and re-author.I will let you know how i go on.
Thanks very much for you help -
After converting to 352x288 it played fine on my DVD player.
Thanks ChrissyBoy -
help for svcd2dvd
By dougal69 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 12th Sep 2011, 18:05 -
Svcd2dvd
By dobbin in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 24th Jan 2011, 12:19 -
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 12:45 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 27th Sep 2009, 13:41 -
svcd2dvd
By tempac in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2008, 22:43
