Hi Folks
Been experiencing a weird problem with files frameserved from PremierePro to TmpgEnc. Whenever exporting from Premiere, the video produced by TmpgEnc takes twice the normal amount of time to re-encode and the resulting mpeg is twice the running time. The second half of the mpeg is black/blank video. A 1 minute test clip comes out to 2 minutes (1 minute of the test video plus 1 minute of blankness).
Already tried uninstalling everything that was installed after the last time everything was working fine. Also tried uninstalling/reinstalling premiere, the pluginpak framserver and tmpg.
Any ideas???
tia!
-funsoul
2x2.4/533 xeons @ 3.5GHz (15x232.4), 2gig ocz pc3200, asus pc-dl, 74g raptor primary, 2x120g WD (raid0), sapphire 9800pro, turtlebeach santa cruz, promise fastrack100, dvdr, watercooled
Hi Baldrick
Newp...haven't tried the directshow reader priority (yet)...will play with it this weekend.
Funny thing about the source range....it shows the video only (without the extra blankness). If the wizard is used, everything seems fine until it gets to the estimated filesize screen. That's the first place it shows that the video's going to be double-size.
Thanks for directshow suggestion (I'm not clear on directshow so am not sure how that might help but will certainly give it a try).
Thanks again!2x2.4/533 xeons @ 3.5GHz (15x232.4), 2gig ocz pc3200, asus pc-dl, 74g raptor primary, 2x120g WD (raid0), sapphire 9800pro, turtlebeach santa cruz, promise fastrack100, dvdr, watercooled -
You can also try Debugmode FrameServer or maybe pluginpak is the same?
Yeah...that's the one I'm using. Also tried the videotools.net one...same results.
Something must've changed and/or corrupted...never had this problem before.2x2.4/533 xeons @ 3.5GHz (15x232.4), 2gig ocz pc3200, asus pc-dl, 74g raptor primary, 2x120g WD (raid0), sapphire 9800pro, turtlebeach santa cruz, promise fastrack100, dvdr, watercooled
frameserving dvd to premiere to avoid demuxing, is it possible?
By codemaster in forum EditingReplies: 3Last Post: 7th Jan 2011, 15:11 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
AVCHD thru Premiere CS4 encodes hiccups in audio
By ddane in forum Video ConversionReplies: 5Last Post: 11th Dec 2009, 16:21 -
frameserving movie from premiere pro cs3 to avisynth
By colin66 in forum Newbie / General discussionsReplies: 10Last Post: 29th Oct 2007, 07:47 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 06:01
