ok, i have 2 dvdplayers of wich one a MAGNUM dvd/divx player plays divx/xvid. but i downloaded several stargate avi's which when i put them on a cd-r play perfectly on my player but if i use a dvd and put up to 10 series on it the player refuses, how come??? can someone help please,
thank you
Some crappy divx players don't support divx/xvid on dvd media.
But you can try different dvd media and try burn one divx or xvid (use rewritable to test) and different dvd modes(ISO, UDF). -
If the avi`s are XVID try using mpeg4modifier.
load the avi and tick "unpack" which is under packed bitstream. -
The files you downloaded may have been encoded with GMC or QPEL which many Divx/DVD players don't support.
The audio may not be compatible with your Divx/DVD player.
The audio bitrate may be too low for your player (for some reason many players won't play low bitrate mp3 audio).
Be sure to finalize your DVDs. Many players won't properly play disks that haven't been finalized. -
Are there some problems with the DVD players when they play AVI with a MP3 VBR? My DVD player can play DivX, but it can play MP3 and with VBR it doesn't have good performances.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Is this DVD Player can play Divx or XviD?
By php111 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 6th Oct 2007, 07:29 -
Best Divx/Xvid DVD Player!!!
By SIRCOOKS in forum ComputerReplies: 10Last Post: 23rd Aug 2007, 10:49 -
Divx/Xvid on dvd player annoyances
By dude112 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 13th Jul 2007, 21:21 -
DivX/XviD file on DVD player
By Bizouman in forum Video ConversionReplies: 4Last Post: 4th Jul 2007, 02:36
