Just getting my toes wet with encoding and just for practice I am trying to encode a 10 second or so vidie clip as a VCD and I keep getting this error: TMPGENC caused a divide error in module XMDAUDIODECODE.DLL at 0167:1000b66e. I was getting it earlier in the process but after I tried playing around the environmental settings on the VAPI Plug-in Tab (Priority), I got farther along. Any ideas why this is happening? I'm using version 2.00.29.
thanks
That DLL sounds alot like XinMPEG Digital Audio Decoder, which doesn't make sense what so ever if you are using TMPGEnc, you don't happen to have Xing anywhere installed have you ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
if this is a divx file or one you downloaded it may have a corruted frame which tmpenc will stop on every time, one fix to this whic works most of the time is to use vdub and make a direct stream copy. Then encode the copy.
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 16:32 -
TMPGEnc Xpress 4.7.4.299 crashes at 50%; audio related
By CasanovaFly in forum Video ConversionReplies: 0Last Post: 28th Mar 2010, 23:20 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 10:03 -
Stalls at 99% complete and then Progress crashes
By upperholme in forum ffmpegX general discussionReplies: 2Last Post: 1st Aug 2008, 14:35 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2007, 00:13
