Anyone know a very simple (free) program in which you can burn CDR(W).
The reason is that I had alway used "Sony Spressa Hotburn". It came with my 5x CDR(W) Burner - yes, I know, I'm old school. It costed $500 when it came out!
But back then i was using Windows98, and now i got Windows 2000. Now i think the program is Windows 98 ONLY, because "Hotburn" counldn't find my CD-ROM.
So do anyone know a freeware program that's easy as hell to use.
All I want to do is insert a CD in my CD-ROM and click on a program and then click BURN....
And for music, a "drag & drop" or "add files" interface....
All in one free program...PLEASE, something EASY people!
Results 1 to 10 of 10
Is this program any good??? Why is the rating so low? And what is it about NOT burning certain files?Originally Posted by Bob W
I have only used the program to burn some data CD files and it worked just fine doing that.
Not sure if they are simple to use as you want but I
recommend >
CDBurnerXP Pro - Very Nero like. http://www.cdburnerxp.se/
BurnAtOnce - Simple, small, but interace take some getting used to. http://www.burnatonce.com -
cdrecord, cdrdao for those who don't suffer from command line disability
/Mats -
software playing is no cd burning. moving you the computer forum.
oh, i forgot to tell ya, it's an external CDRW...
Okay i downloaded DeepBurner, I know how to create data CD's, but not yet audio, that's because i haven't tired.
But my question is that i have a VCD that automacticly play on my DVD Player (stand alone). And i want to know how do you actual DIRECT copy one CD to another???
I tired dragging all of the files, but that was just a stupid thing to do because it's just going to be a data CD, which i don't want. I want an exact copy of the CD i put in my CD-ROM. (a duplicate)
and please explain it step by step...on what to click on....
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 08:49 -
Please suggest a simple portable USB DVD burner to purchase in the US
By suirauqa in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Jun 2010, 07:49 -
simple editing program
By devdev in forum EditingReplies: 6Last Post: 4th Jun 2009, 07:40 -
extremely simple editing program?
By Mikrokosmos in forum EditingReplies: 1Last Post: 31st Jul 2008, 16:27 -
Simple free program editing.
By Traveller in forum EditingReplies: 12Last Post: 24th Oct 2007, 00:42
