Hi Everyone,
I have just got Firewire and now want to copy all video from my tapes onto computer and CD data disc, I would like to know what is the best freeware capturing software, I have tried WinDV but was wondering if there is any other... and also a good software that can convert the AVI files to Mpegs without any or much loss of quality..
Lucky_9
Lucky
Hi Lucky_9,
Transferring ("capturing"): You can't go wrong with WinDV. There are others, like DVIO and AVI_IO - I've not used 'em coz I found WinDV suited me perfectly.
Encoding AVI to MPEG, in no particular order:
TMPGEnc Plus
Cinema Craft Encoder
Mainconcept MPEG Encoder
Canopus ProCoder
Quenc
WinAVI Video Converter
The above are regularly used and have their fans. Some are better than others in terms of price, speed, (perceived) quality. Try 'em and see what you like...
As for little or no loss of quality, there's always some loss of quality when encoding - it's inherent in the process. It's just a question of what you like...
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
True Newbie Here....be gentle. Mini dv questions.
By jsup in forum Newbie / General discussionsReplies: 7Last Post: 8th Nov 2009, 10:05 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 02:11
