Basically I have the philips 642 player and I don't know what options have changed in AutoGK, but now whenever I encode something it throws in some serious b-frames that screw everything up. It either doesn't play or it looks insane on screen.
I'd rather not go to divx home theater mode but I may have to. What settings do I need to do and where do I do them? AUtoGK has shit for options quite honestly, and in vdubmod I just saw quality dropdowns which weren't descriptive
This USED to work.. please help![]()
I've got a Norcent 220, which is almost the same machine and has the same ESS chipset (wulf109 confirmed this). I've done several XVID conversions using AutoGK and I've had no playback problems, I just made sure that I selected the ESS compatibility options when I installed it - I think the only way to select these options is at the point of installing, so you may want to reinstall. CTRL-F9 gives you 'hidden' options, but controlling B-frames is not part of the options.
I usually had ESS compat selected, maybe I missed it this time around, but I'll have to try.
I was reading another one, does it have consecutive B-frame amounts that you can change? And thatnks for the C-F9 tip
.ts to XviD with AutoGK: Some audio probs?
By vieekk in forum Video ConversionReplies: 0Last Post: 8th Feb 2012, 11:02 -
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 14:37 -
MiniDV to DivX/XviD (w/ AutoGK): audio out of synch due to dropped frames??
By alexon in forum Video ConversionReplies: 6Last Post: 17th Dec 2009, 03:54 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 06:00 -
converting to xvid with autogk
By myname77 in forum Video ConversionReplies: 10Last Post: 5th Jul 2007, 08:38
