Hello
I've got a playback problem : sound is jerky while playing xvid or divx with ac3 spdif passthrough. Dobly Digital light flashes irregularly on my external decoder.
It happens with Media Player Classic and Zoom Player. I'm using latest versions of reclock and ac3filter. I've tried other versions without success. I had no problem on my former system.
Has anyone an idea ? It may be a settings problem.
Current state of my system :
windows xp pro sp 2
media player classic 6.4.8.3 / Zoom Player pro 4.0.3
ac3filter 1.02a_test3
reclock 1.5 beta 8
Creative Audigy 2 soundcard
Try using media player classic's own ac3 decoder. disable spdif passthrough.
I think its a problem with the creative audigy 2 soundf card (i got the same card) and the problems is the same for me. use the softwares decoder and it should work fine. -
Thanks for your reply.
I also thought it could be due to the drivers since I updated them. But as I did not try to play ac3 just after, I could not be sure.
How to passthrough 2 channel DTS and AC3 files?
By Phat J in forum AudioReplies: 4Last Post: 10th Jan 2012, 14:45 -
passthrough dts and ac3, reciever
By maxone71 in forum Software PlayingReplies: 1Last Post: 17th Oct 2011, 16:45 -
DD 5.1 spdif passthrough for gaming
By MR 3 in forum AudioReplies: 2Last Post: 10th Sep 2010, 09:55 -
[VLC] AC3 video file + spdif output = stereo?
By SANAFABICH in forum Software PlayingReplies: 0Last Post: 10th Aug 2008, 17:59 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
