how can i remove those cloudy effects in the video that i captured? especially in a little dark areas? i used virtualdub still, i am not satisfied with the result. also, what if there are many shakes in the video? is there a way to avoid them?
and i captured something from the tv, how can i improve the captured video?
i would like to create an effect similar to the movie "Alias" where multiple camera angles. as for me, i took a shot of the driver, then i took a shot of the road. here's the result http://karlo-1.tripod.com/angle.html
i would like it to have sound effects and cool background musics. what will i do?
and also, is there a capture program that will avoid dropped frames? currently, i captured that video from my analog video cam and used virtualdub, my compression is lossless jpeg. still, it eats 3 gb for 19 minutes of video. i can't use divx because the audio is not synchronized with the video. i am using windows xp pro sp2 pentium 3 700mhz, 320 mb ram, 64 mb video card.
and also, in addition, when capturing videos, i would like it to be compressed immediately using DivX. but the audio of the video is not synchronized. i tried every sync method in virtualdub and still, it dosen't work.
note: i have the latest DivX codec... I mean, I have a video editor, well, where can i get sound effects and background musics for free?
note: I am capturing via USB. Well, I must capture it, and it must be compressed. Because if I am going to use the uncompressed version, it will take up my hard drive's space. I only have 4 gb of space left...
You need a bigger hard drive.
DivX is just far too slow to do realtime captures, stick with mjpeg or huffyuv (bigger drive needed badly!).
Drop the aspect ratio to avoid dropped frames. You could try VirtualVCR, which seems to do slightly better than virtualdub.Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
Even Picvideo mjpeg is NOT lossless.
I don't know why you say VirtualVCR is VFW only, and I have no idea why you wouldn't be able to capture audio as well.
Are you sure the device works properly?
Why RGB16? Use YUV2 and filter it. Virtualdub will do that.
You say the aspect ratio is OK. How big is it? The larger it is, the more likely to get dropped frames, no matter what codec.
How fast is your hard drive?
Again...I would suggest getting another, faster hard drive for captures, before worrying about other stuff.Cheers, Jim
My DVDLab Guides -
@reboot: Correction: VirtualVCR is WDM only
Virtualdub is VFM only. Works with WDM because of warpers (vfm2wdm): Not always the best solution.
Use PicVIDEO at 19 if you can.La Linea by Osvaldo Cavandoli
Originally Posted by SatStorm
Confused about High Definition video capturing and editing. Please help.
By Ashfaqul Taposh in forum Newbie / General discussionsReplies: 16Last Post: 27th Apr 2012, 13:48 -
Capturing and editing game video w/ HD-PVR
By helloitsdan in forum Capturing and VCRReplies: 8Last Post: 29th Jul 2009, 10:47 -
need help: topic - video/audio capturing editing software
By Uebermensch1984 in forum EditingReplies: 2Last Post: 29th Dec 2008, 23:49 -
Choosing a Video capturing/editing program
By affiatati7 in forum Newbie / General discussionsReplies: 1Last Post: 5th Nov 2008, 07:05 -
Which Hard Drives/setup are best for capturing video/video editing?
By Balefor in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2008, 13:24
