Hi,
I have a custom background image that I use when authoring DVDs with DVD Author -- when I play the DVD on my computer using WinDVD, my background image is displayed in full correctly, however when I play the same DVD on my standalone DVD player the very top and very bottom of the image is missing / cropped on my TV. This makes the image look stupid, although there's only a bit missing that bit is essential to the design.
My TV is a 'full screen' (not Widescreen) TV and it is PAL. When I first made the background image I used 720x480 for its size. After the first time I saw the missing top and bottom bit I realized these are the NTSC screen dimensions and so remade the image using the PAL dimensions of 720x576. This made no difference, it still looks fine on my PC using WinDVD but with the same problem on my TV.
Any ideas how to resolve this?
Thanks,
MS
I think it's a TV problem not a DVD problem.
Some TVs, especially older TVs cut the top and bottom off of the picture.
I have an older TV that cuts the "Bottom Line" off while watching ESPN.
If it showed correctly on your computer, it's right on the DVD, TV settings need adjusting.
Question on DAR and best image size for a pal movie menu background
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2011, 11:42 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2008, 00:01 -
Tmpgenc DVD Author 3 Custom Background Quality?
By haym in forum Authoring (DVD)Replies: 1Last Post: 29th Jul 2008, 19:49 -
Background clip from movie - TMPGEnc DVD Author 3
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 11th Sep 2007, 03:02 -
Background audio with still image on TMPGEnc DVD Author?
By tikigod19 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2007, 14:44
