Heya there im new to the video help community and i was trying to
get rid of those annoying Logos in some videos i have on my pc
i tried using the Virtual dub mods "MSU subtitle and logo remover" and Logoaway but i cant figure it out !! can sumone please help this poor old
nOOb !!!!![]()
Try this one for the delogo filter
https://www.videohelp.com/forum/viewtopic.php?t=232456&highlight=delogo
You can probably find it at neuron2.net, or google.Read my blog here.
I like the "Region Remove" filter by Shaun Faulds (google it). Easier to use than delogo.
Cheers, Jim
My DVDLab Guides -
This "region remove" filter is another in a long line of filters that BLUR and smear out an area. Not good! Delogo can do that too, but it's finest feature is that it REMOVES the logo and reveals the video underneath.
I started the above mentioned thread, and there are some good pics there of what can be done. After working on it, I was able to get the result to look even better. Until someone creates something better, I'd go with Delogo and skip the blurry filters entirely. -
hey there ive figured the whole "logo" thing now but when in virtualdub
i try and save the avi file when i open it there no video ?? can sum1 help?
I personally frameserve the video out once I apply the delogo filter. This saves me from using many many gigs outputting a new AVI, and I've never had the problem with no video doing it that way.
replicate dirt on logo removal
By mathmax in forum EditingReplies: 26Last Post: 11th Oct 2011, 18:35 -
Logo removal by using 2 sources
By pfxz in forum RestorationReplies: 13Last Post: 8th Feb 2011, 23:01 -
LOGO removal from WIdescreen black bar
By CBrianA in forum EditingReplies: 2Last Post: 6th Feb 2010, 10:10 -
Good Results on Video to Photo Logo Removal?
By Disco Makberto in forum EditingReplies: 28Last Post: 14th Dec 2009, 20:40 -
Removal of TV logo from VOB files?
By guy24s in forum EditingReplies: 6Last Post: 16th Nov 2009, 23:25
