well im not to sure which forum to post this under so better safe then sorry ill post it here ive been tryin to search the forum for a good guide on how to make .mkv files dvd ready but the only ones ive seen is for vcd now to give some background i ran the video through tmpgenc and it made a .m2v and .wav file but it didnt give me subtitles i wanna keep the subs being that the video is in japanese how could i do that and is it possible to add them to the m2v and if so how if not what programs would i need to do this
thanks in advance for all help given
extract the subs with mkvextractgui or virtualdubmod(under stream->stream list)
if it is srt subs you can author a dvd with switchable subs using dvdauthorgui, add the m2v,wav and srt and author,burn. done.
if it is sub/ifo subs you can use subtosup and author with ifoedit, add the m2v, wav and sup and author,burn. done. -
the files are srt now the only other thing is it has s_text/ssa and s_text/utf8 do i use both of them or which do i use
i tried to use both subtitles with virtual dub and i get a error that says some errors were found read the report but when i goto read the report the program crashes on me -
ssa should look the nicest but you would have to hard encode them. If you want switchable subs, go with the plain srt.
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
