I want to know if I can take a cd, make it into a mp3 file. Also from mpeg, turn the song that is playing into a mp3 also. If so, which program and how?
Please reply
ok i hope i understand your question since your chronological order is screwed up but i think this is what u want to know-
If lets say your dvd player cannot play mp3s, you can make a vcd that holds 98 tracks in vcd standard!!
NOTE- vcd only holds up to 98 tracks so no need for xvcd
If you want to convert your mpg to mp3, this is the only way i know-
Import the mpg into tmpgenc, go to file, then output file to wav
From there use- Electronic cosmo MPEG Suite 2000.
Its teh fastest encode and decoder of mp3s i have ever seen
Decodes in 8 sec flat with a 600 MHz 128 mb ram
Encodes in 19 sec flat with same specs.
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one. -
what do you want to know?
if its possible to make the sound of an mpeg into mp3. yes you can. split video and sound. turn sound into vaw and make it mp3 in your favorite mp3enc.
and as said above the outher way works fine too..
Well, I am the slime from your video.
Oozin' along on your livin'room floor.
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 04:47 -
HP Product Assistant
By jyeh74 in forum ComputerReplies: 1Last Post: 3rd Jul 2009, 18:17 -
Can remote assistant work between XP and Vista?
By yoda313 in forum ComputerReplies: 6Last Post: 7th Jan 2009, 17:53 -
How can I associate cut assistant with virtualdubmod
By pondleaping in forum EditingReplies: 3Last Post: 2nd Aug 2007, 09:06 -
two problems with virtualdub1.71 and its cut assistant
By pondleaping in forum EditingReplies: 7Last Post: 7th Jul 2007, 12:42
