Hi the last movie that I tried to burn came up with this messege during the encoding process of dvd shrink.
"Dvd shrink encounterd an error
Failed to read file D:\.
overlapped I/O "
does any1 know what this means does it mean that the disc was abit scratced or something like that? thx all![]()
If you get the same thing with DVD Decrypter, you have a bad disc. I/O errors are disc problems. You should first try cleaning the disc. If that doesn't work, you can try repairing the DVD with a repair kit shch as Skip Dr or Repair Dr. I've had two discs recently that gave me I/O errors. One became readable after repairing. The second was damaged beyond repair. Damage can be from scratched discs or internal problems with bad quality media.
thx very much cine I did have the same problem with decrpypter,I will try cleaning them,what can u clean them with meths???
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31 -
any1 figure out THE QuEeN
By steamedPS in forum DVD RippingReplies: 8Last Post: 12th May 2007, 19:14
