I am trying cut out some scenes from a DVD I have useing TMPGEnc DVD but I am haveing a problem with it recognizeing 5.1 audio sources. I see that there is a plug in for two channel dolby digital, but what can I do about it not being able read the 5.1 audio format?
Also, on a side note would VideoReDo re-arthur the DVD like
TMPGEnc DVD will after cutting out some scenes?
Thanks,
-Dman
tmpgenc dvd author should be able to read 5.1 audio. are you importing vobs from a dvd? how did you make the clips?
Without the AC-3 plugin, TMPGEnc DVD Author cannot encode to AC3, but should be able to read it just fine. I frequently import video from dvds that contain AC-3. In the 'edit' window, I don't get any sound when I play the clip, but it authors fine.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
DVD Shrink and TMPGENC bitrate problem
By haddockd414 in forum DVD RippingReplies: 2Last Post: 12th Mar 2008, 13:31 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
