    Apr 2005
    Lancs, UK
    Hi there
    I recently bought a DVD burner (BENQ DW1620) and installed it and am using Nero Express 6. I have a 19GB hard drive with about 9GB of software and files on it. However, after burning a few DVDs I noticed that my hard drive only had about 1GB of space on it. Initially I uninstalled a few unneccesary programs and then noticed I had 9GB free again. I've copied a few DVDs recently and had no problems. However after copying a DVD today I then tried to copy another. However, I got a message saying that I had no free space left on my hard drive. It appears that somehow my PC is saving the image of the DVD I'm copying. I think it may be something to do with buffer underruns or to do with the buffer cache. How can I prevent this from happening? It seems like everytime I copy a DVD I just get a hard drive full of data that I can't find or delete.
    Thanks in advance
  2. Look in c:\Documents and settings\username\temp
    Delete everything in that folder.
    Cheers, Jim
    My DVDLab Guides
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I think its probably time you upgraded your hard drive.
    19GB is very limited, especially with backup of dvds, considering each dvd is like approx 7GB.
    Apr 2005
    Lancs, UK
    Thanks for the advice - I've deleted everything in the temp folder - hopefully that should free up spme space. Thanks
