I use ATI Capture software to capture my video and last night I noticed that when captureing AVI's I have the many options of what type of compression I would like 2 use but if I try captureing under most of these I eather get a lock up of the TV caturing thingy or a message telling me I need these codecs so where do I get them all ?
Thanks for Your Help
check the left side of ur screen under tools, read about em, other wise i dont know
Not sure whether it will solve your problem, but you may wish to try the Nimo Codec pack.
You can find it under the tools section.
Cheers
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 21:26 -
Dv Codec
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 15th May 2008, 14:10
