  1. hey chrissyboy, I just did a new install on my computer. I put rc8 sometimes it works and sometimes it doesn't. So I decided to go back 1.5 because I had no problems with it. When I reinstalled it I get this message
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ComponentModel.LicenseException: The license key used to license this Xceed product has expired. Please contact Xceed Software if you need additional time to evaluate the library, or if you wish to purchase a registered license.
    at Xceed.Utils.Licensing.cd.a(String A_0, Type A_1, Boolean A_2)
    at Xceed.FileSystem.Licenser..ctor()
    at Xceed.FileSystem.FileSystemItem..ctor()
    at Xceed.FileSystem.AbstractFolder..ctor()
    at Xceed.FileSystem.DiskFolder..ctor(String folderName)
    at _2b02761aea07325e.x210ff09a2516b1a7.xe539963764b40 d25(String x8dd66a714110d48d)
    at _2b02761aea07325e.x210ff09a2516b1a7.x60f18f1e09a87 437(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 1.51.2.0
    Win32 Version: 1.51.2.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    RegistrationSDK
    Assembly Version: 1.0.1608.40231
    Win32 Version: 1.0.1608.40231
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/RegistrationSDK.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Security
    CodeBase: file:///c:/windows/assembly/gac/system.security/1.0.5000.0__b03f5f7f11d50a3a/system.security.dll
    InProgress
    Assembly Version: 1.5.0.0
    Win32 Version: 1.5.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/InProgress.DLL
    MagicLocalLibrary
    Assembly Version: 1.7.4.0
    Win32 Version: 1.7.4.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/MagicLocalLibrary.DLL
    FolderBrowser
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/FolderBrowser.DLL
    AxInterop.SHDocVw
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/AxInterop.SHDocVw.DLL
    DevComponents.DotNetBar
    Assembly Version: 4.6.0.0
    Win32 Version: 4.6.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/AxInterop.CodeLock.DLL
    Accessibility
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Interop.CodeLock.DLL
    Interop.SHDocVw
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Interop.SHDocVw.DLL
    Xceed.FileSystem
    Assembly Version: 1.0.29.0
    Win32 Version: 1.0.29.0
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/Xceed.FileSystem.DLL
    SVCD2DVD.HelperUpdates2
    Assembly Version: 1.0.1806.19400
    Win32 Version: 1.0.1806.19400
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.HelperUpdates2.DLL
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.HelperUpdates.DLL
    SVCD2DVD.VCDGear
    CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD/SVCD2DVD.VCDGear.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    marc
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What is your system clock set to?
  3. that must be the problem it was set to the year of 2017. will retry it. thank you.
