  1. Hi,
    I'm investing in a dual 2,5 and I have heard somewhere that it's a good thing to buy a better DVD-R burner than the one that there is in it.
    So my question is.. which is the best for the $, and ofcourse, it has be mac friendly.
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    hi.
    search the forum for NEC, Pioneer, Plextor.
    you should come across this:
    https://www.videohelp.com/forum/viewtopic.php?t=265142
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. you might consider waiting a few weeks. rumor is the new G5's will have a dual layer burner in them. it might save you $100.
    again rumors only. go to think secret. sorry did not copy the url but will in a 'reply'
    rotut
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
  4. here it is:
    http://www.thinksecret.com/news/0504g5notes.html
    it links the earlyer one.
    again might no be correrct but not the time to buy I think.
    rotut
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
    Jan 2004
    Finland
    I personally like NEC-burners, as they can be flashed with Mac, bitsetted etc. easily. And they get Mac-support always earlier than later. It's mac-friendly
    But, before buying new burner, why not flash original (Pioneer?) with retail version firmware? Apple uses tampered firmware. You propably have to use PC for flashing (Apple updaters only do Apple firmware?), but might be worth it.
    i-NCO
  6. I'm also a big fan of NEC burners. I've had on-again, off-again problems with Pioneer (dvr-104, etc.), so recently got an NEC 3520a which does +R DL and will soon do -R DL with a firmware update. It's cheap ($50), fast, has a Mac flasher available, a ton of available "official" and "unofficial" firmwares, and is recognized by Apple's iApps with Patchburn. Digging it. No coasters nor glitchy output thus far.
    I'm assuming if Apple includes DL burners in the new Macs, it will be the Pioner DVR-109?
    :: rockinsage ::
    Apr 2005
    Australia
    I've always found lacie to make great mac-friendly burners.
    There is a new one out/out soon with DL and lightscribe, which is where you turn the disc upside down and the laser scribes an image.
    The first two on http://www.lacie.com/products/range.htm?id=10014]this page have lightscribe, with one of them including toast.
    The cd-r and dvd-r media for this is expensive if you want to scribe something though, but media drops in price rapidly.
    Jan 2004
    Finland
    But they don't make actual mechanism, they put Nec/Pioneer/Panasonic whatever. into enclosure and make support file etc. required.
    For example, my (internal) Nec ND-2500A uses LaCie support file, which is made for external LaCie drive.
