What in hours are the amounts of Video that can be transfered onto a 4.7 gig dvd and a dual layer dvd
Hard to say. The amount is purely a function of the bitrate. Dropping to something like 352x288 (I can't remember if 288 is right for PAL) will allow you to drop the bitrate. In return, more video will fit. How much material do you have?
Yup, in VCD quality, 6-7 hrs on a single layer DVD is possible.
/Mats -
It is a 3 hour plus homemade motorbike video I want to cature and transfer to pal dvd was thinking of doing onto a dual layer then shrinking it down to go onto a 4.7g dvd,
This is wrong IMO. If you want 4.7 g calculate the average bitrate to match this size without shrinking. Well 3 hours motorbike (read high action) 4:3 fullscreen PAL probably interlaced in one 4.7 DVD full D1 res will result in bad quality IMO. The suggestion is either use 2x 4.7 DVDs (or DL if you can burn it) or half D1 resolution.Originally Posted by mick094
There are other approaches that can be used as motion adaptive deinterlacing and motion adaptive bluring in avisynth, but looking at your first post you will have hard time learning all this stuff. -
I imagine 3 hours would be no sweat for dual layer. And you could get good results for 3 hours on a DVD-5 if you do it right.
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
VHS/ DVD Go-Video problem. Bad video, good audio
By Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 21:31 -
What.When) is DVD video (or mpeg video for DVD) pixel ratio 1:1 or 1:1.09
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 21st Mar 2008, 08:05 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
can faulty/bad dvd-video dvds make ripples/whitelines in video?
By wiak in forum MediaReplies: 3Last Post: 22nd Jul 2007, 13:08
