I have an AVI file that required the K-lite mega codec pack just to play on Window media player. Now I want to convert it to DVD, but none of the authoring software I have will recognise the file. Any suggestions?
You need to convert the avi to a DVD COMPLIANT MPEG2 first. Use Mainconcept mpeg encoder. Then use tmpgenc dvd author to author. To avois sync problems separate audio first with virtualdub mod.
Nothing is impossible for DiLeMmA says so!
See my guide on how to batch author dvds!
https://www.videohelp.com/forum/viewtopic.php?t=255213 -
You may also try avidemux (freeware) to convert your avi to DVD compliant files. Not as fast as mainconcept, but much cheaper...
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
...and no file requires a codec pack.
/Mats -
The proper way to use a codec pack is to first run GSpot to identify the specific codec your media file requires, then install only that one codec from the pack.
Bad mojo happens if you install the entire codec pack.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Originally Posted by drjtech
Make that a sticky!
/Mats
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 22:37 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 06:14 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18 -
How does AutoGK work for making SVS to avi files?
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 14:08
