I've Just checked few a few projects I have done with RC8 and discovered chapter problems occuring, unfortunatly I cant upload the files as stupid me deleted them thinking everything would be ok. anyway I will post the logs, from two different projects if that will help. The first project produced no chapters at all, the second produce only three chapters, the last chapter being at the 20min mark(this was a full lenght movie BTW)
LOG 1
LOG 2************************************************** ******************
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Name: SVCD2DVD 2.0 RC8
Title: 2.0 RC8
Version: 2.0.1923.27967
Executable: C:\Program Files\BadgerSoft\SVCD2DVD 2 BETA\SVCD2DVD.exe
Executable size: 2.24 MB
Executable size in bytes: 2351187
Executable CreationTime: 07/04/2005 15:46:08
Executable LastWriteTime: 08/04/2005 08:20:09
Executable LastAccessTime: 10/04/2005 20:23:14
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 511 MB
Free Physical Memory: 296 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: KT266_
Computer Model: AWRDACPI
System Type: X86-based PC
Computer Name: MAINCOMP-441045
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: MAINCOMP-441045\Maincomp
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 2000+
Description: x86 Family 6 Model 8 Stepping 1
CPU Speed: 1.673GHz
CPU FSB: 133MHz
L2 Cache Size: 256 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: NVIDIA GeForce FX 5200
Processor: GeForce FX 5200
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 128 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 26.7 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 8.19 GB
********************* END OF SYSTEM INFORMATION ********************
Processing assets for DVD creation
Resampling audio and adding Nav Packs
Processing cons1.mpg
21:29:34: ffmpeg version 0.4.9-pre1, build 4750, Copyright (c) 2000-2004 Fabrice Bellard
21:29:34: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
21:29:34: built on Apr 4 2005 15:51:59, gcc: 3.2.3 (mingw special 20030504-1)
21:29:34: Input #0, mpeg, from 'D:\Movies\SVCD\constantineTC\cons1.mpg':
21:29:34: Duration: 00:57:29.7, start: 0.733356, bitrate: 1878 kb/s
21:29:34: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, 2520 kb/s
21:29:34: Output #0, dvd, to 'D:\Movies\SVCD\constantineTC\cons1_S2D.mpg':
21:29:34: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, q=2-31, 2520 kb/s
21:29:34: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
21:29:34: Stream mapping:
21:29:34: Stream #0.0 -> #0.0
21:29:34: Stream #0.1 -> #0.1
21:33:37: video:687255kB audio:94352kB global headers:0kB muxing overhead 1.288972%
Processing cons2.mpg
21:33:38: ffmpeg version 0.4.9-pre1, build 4750, Copyright (c) 2000-2004 Fabrice Bellard
21:33:38: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
21:33:38: built on Apr 4 2005 15:51:59, gcc: 3.2.3 (mingw special 20030504-1)
21:33:38: Input #0, mpeg, from 'D:\Movies\SVCD\constantineTC\cons2.mpg':
21:33:38: Duration: 00:58:16.1, start: 0.733356, bitrate: 1890 kb/s
21:33:38: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, 2520 kb/s
21:33:38: Output #0, dvd, to 'D:\Movies\SVCD\constantineTC\cons2_S2D.mpg':
21:33:38: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, q=2-31, 2520 kb/s
21:33:38: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
21:33:38: Stream mapping:
21:33:38: Stream #0.0 -> #0.0
21:33:38: Stream #0.1 -> #0.1
21:37:05: Done: Processing assets for DVD creation
Authoring DVD Folders
21:37:05: video:701357kB audio:95624kB global headers:0kB muxing overhead 1.289092%
21:37:05: Creating TitleSet # 1
21:37:05: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
21:37:05: -->: DVDFolders creating VTS
21:37:05: -->: VTS 01
21:37:05:
DVD Folders: Processing D:\Movies\SVCD\constantineTC\cons1_S2D.mpg...
21:38:08:
DVD Folders: Processing D:\Movies\SVCD\constantineTC\cons2_S2D.mpg...
21:38:09: !!!: Cell boundary GOP is not closed - only a warning
21:39:20:
21:39:21:
21:39:21: Finalising DVD...
21:39:23: SVCD2DVD: DVDfolders
21:39:23: -->: DVDFolders creating table of contents
21:39:23: scanning D:\Movies\SVCD\constantineTC\SVCD2DVD_OUTPUT\VIDEO _TS/VTS_01_0.IFO
21:39:23: Finalising DVD...Done
21:39:23: Done: Authoring DVD Folders
Title: 2.0 RC8
Executable LastAccessTime: 17/04/2005 12:59:56
Version : 5.1.2600
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Free Physical Memory: 312 MB
CPU Speed: 1.674GHz
CPU FSB: 133MHz
Video Ram: 128 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 40.2 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 11.5 GB
Processing nbp-cu1.mpg
14:00:25: ffmpeg version 0.4.9-pre1, build 4750, Copyright (c) 2000-2004 Fabrice Bellard
14:00:25: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
14:00:25: built on Apr 4 2005 15:51:59, gcc: 3.2.3 (mingw special 20030504-1)
14:00:25: Input #0, mpeg, from 'D:\Movies\SVCD\cursed\nbp-cu1.mpg':
14:00:25: Duration: 00:44:30.6, start: 0.220000, bitrate: 2483 kb/s
14:00:25: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, 2450 kb/s
14:00:25: Output #0, dvd, to 'D:\Movies\SVCD\cursed\nbp-cu1_S2D.mpg':
14:00:25: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, q=2-31, 2450 kb/s
14:00:25: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
14:00:25: Stream mapping:
14:00:25: Stream #0.0 -> #0.0
14:00:25: Stream #0.1 -> #0.1
14:03:29: video:719357kB audio:73045kB global headers:0kB muxing overhead 2.951082%
Processing nbp-cu2.mpg
14:03:30: ffmpeg version 0.4.9-pre1, build 4750, Copyright (c) 2000-2004 Fabrice Bellard
14:03:30: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
14:03:30: built on Apr 4 2005 15:51:59, gcc: 3.2.3 (mingw special 20030504-1)
14:03:30: Input #0, mpeg, from 'D:\Movies\SVCD\cursed\nbp-cu2.mpg':
14:03:30: Duration: 00:45:36.1, start: 0.220000, bitrate: 2419 kb/s
14:03:30: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, 2450 kb/s
14:03:30: Output #0, dvd, to 'D:\Movies\SVCD\cursed\nbp-cu2_S2D.mpg':
14:03:30: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, q=2-31, 2450 kb/s
14:03:30: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
14:03:30: Stream mapping:
14:03:30: Stream #0.0 -> #0.0
14:03:30: Stream #0.1 -> #0.1
14:06:36: video:716149kB audio:74843kB global headers:0kB muxing overhead 3.010643%
14:06:36: Done: Processing assets for DVD creation
Merging Titles
TitleSet #1
Merging: nbp-cu1_S2D.mpg
Merging: nbp-cu2_S2D.mpg
Correcting PTS values: nbp-cu1_S2D_VTS.mpg
14:08:46: ffmpeg version 0.4.9-pre1, build 4750, Copyright (c) 2000-2004 Fabrice Bellard
14:08:46: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
14:08:46: built on Apr 4 2005 15:51:59, gcc: 3.2.3 (mingw special 20030504-1)
14:08:46: Input #0, mpeg, from 'D:\Movies\SVCD\cursed\nbp-cu1_S2D_VTS.mpg':
14:08:46: Duration: 00:45:36.1, start: 0.500000, bitrate: 4881 kb/s
14:08:46: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, 2450 kb/s
14:08:46: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
14:08:46: Assuming PAL for target.
14:08:46: Output #0, dvd, to 'D:\Movies\SVCD\cursed\nbp-cu1_S2D_VTS_PTS.mpg':
14:08:46: Stream #0.0: Video: mpeg2video, 480x576, 25.00 fps, q=2-31, 2450 kb/s
14:08:46: Stream mapping:
14:08:46: Stream #0.0 -> #0.0
14:08:46: Stream #0.1 -> #0.1
14:11:13: video:1435506kB audio:147888kB global headers:0kB muxing overhead 1.763956%
Merging Titles... Done
14:11:20: Creating TitleSet # 1
14:11:21: SVCD2DVD: DVDfolders
14:11:21: -->: DVDFolders creating VTS
14:11:21: -->: VTS 01
14:11:21:
DVD Folders: Processing D:\Movies\SVCD\cursed\nbp-cu1_S2D_VTS_PTS.mpg...
14:11:33: !!!: Cell boundary GOP is not closed - only a warning
14:11:46: !!!: Cell boundary GOP is not closed - only a warning
14:13:19:
14:13:51:
14:13:51: Finalising DVD...
14:13:52: SVCD2DVD: DVDfolders
14:13:52: -->: DVDFolders creating table of contents
14:13:52: scanning D:\Movies\SVCD\cursed\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
14:13:53: Finalising DVD...Done
14:13:53: Done: Authoring DVD Folders
This is fixed in my current dev build and so will be in the next release.
Drop me an email & you can test it!
MultiAVCHD problems; chapter selection crashes program; changing title
By Yanta in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2011, 17:48 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 12:03 -
AVStoDVD Chapter help?
By uEih in forum Authoring (DVD)Replies: 0Last Post: 24th Nov 2009, 07:34 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 21:38 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51
