  1. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    New Codec Alliance: Elecard Joins MainConcept. MainConcept AG, a leader in video codecs and editing technology, announced that it has joined forces with Elecard, a leading codec development company located in Tomsk, Russia...
    http://www.elecard.com/ElecardJoinsMainConcept.shtml
    Never liked the Elecard codec, it once went in strangely and resisted all attempts to reinstall properly..seemed like a 'bad' mpeg codec if there's such
    a thing
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    Elecard codec may not be the best one out there, but many freeware applications use it...
    Let's hope mainconcept keep the semi-freeware version online...
    La Linea by Osvaldo Cavandoli
  3. Member Soopafresh's Avatar
    Jan 2004
    I like Elecard's Mpeg2 codec. Works well on HDTV sources.
    Jan 2003
    India
    Check the Double Precision IDCT and post process in the playback settings and then use directshowsource with mpeg1 and mpeg2-you will see details which were not there earlier.
    The best playback codec for mpg1 and mpg2 in my opinion. You want to remove it-use Radlight Filter Manager and simply reduce the merit.
