Need help figureing out an easy way to setup an aim proxy using Windows XP at home. It has to be an http proxy because thats the only ones I've ever seen work up here.
Any software suggestions?
You have to be more specific. An AIM proxy to accomplish what ? Aha, are you firewalled, preventing you from running AIM?
Yes firewalled and can't run aim. We were using an open http proxy but it sucked and then went down. I figured I'd rather have my own then use another that may disappear.
http://www.instant-tech.com/instant.nsf/root/SCPic1.htm
http://www.trillian.cc/forums/showthread.php?threadid=57670
http://reaim.sourceforge.net/
Do a search for "Socks5 +AIM"
You can create a Socks5 Proxy Server at home on your PC and connect to it from your AIM client at work. You should check that your ISP won't terminate you for doing this. Also, others will find the proxy after a few days and you might have unwanted traffic going to your machine at home.
Doesn't AOL have a web based AIM client? I think they do. -
heh thanks my ISP knows less about computers most end users. Its a small company and when I call to complain I often talk to the owner.
uhm... one of those links is about setting one up under linux, and the other 2 are about changing port numbers in the aim or trillian client which is can already do. Guess I'll keep looking.
Try desproxy which is a TCP tunnel for HTTP proxies...
http://desproxy.sourceforge.net/
The manual may give you an idea on how to set it up for AIM.
Best of luck.
Regards.Michael Tam
w: Morsels of Evidence
Help With Blu-Ray and Cable Box Setup
By Anonymous531 in forum DVB / IPTVReplies: 6Last Post: 1st Oct 2009, 21:12 -
Good setup for home movies and Tivo?
By lened in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2007, 20:41 -
dvd recorder and dvr box setup help
By backdrop001 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2007, 10:29 -
Connecting Bellexpressvu box to current cable setup
By samouellette in forum DVB / IPTVReplies: 1Last Post: 29th Nov 2007, 09:41 -
Home Entertainment setup issues - addition of cable box confuses things
By CodySave in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 12:32
