Hi
I know how to permanently add subtitles to an .avi using virtual dub. My problem is that my subtitles have foreign characters and those chars are shown as bizarre chars after processing. Is there a filter or something that would display the correct characters? Is there another procedure that maybe uses other software that can handle other characters than english language simple letters?
Thank you
Results 1 to 11 of 11
Thank you Druid, it works like a charm. Only problem is that the audio gets out of sunch when "burning" the subntitle in the avi file. I'm sure it's not because of the filter but I'm certainly doing something wrong with the other settings in vdub.
the original file for both video and audio stream. For the audio I use "Direct stream copy" for the video I have no choice but to "Full processing" an dkeeping the original codec (Xvid) and original framerate.
I was thinking when you use the original video for both, you run the risk of synch problems. Make a separate audio file and try to create a vidoe using the audio file and the original video.
If it was you would get a warning message though that you will get sync problems unless you re-encode.
If you want to directstream vbr mp3 audio, use VirtualDubMod, not the regular version.
Spanish subtitle characters in Sony DVD Architect
By Lastman369 in forum Authoring (DVD)Replies: 0Last Post: 13th Apr 2010, 19:42 -
Extended characters
By Jomapil in forum ComputerReplies: 3Last Post: 6th Apr 2010, 13:40 -
your favorite tv characters
By deadrats in forum Off topicReplies: 7Last Post: 17th Mar 2010, 20:37 -
cyrillic characters in Subtitle Workshop
By danielko in forum SubtitleReplies: 0Last Post: 31st Jan 2010, 16:15 -
filename with foreign characters
By namsilat in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 19:34
