Can someone please confirm for me:
I am capturing a film at from a digital receiver, but capturing the picture at 4:3. I know I am loosing some of the broadcast picture, but set at 16:9 I get the squashed version. If I do capture at 16:9 and then want to re-encode to VCD or DVD (both letterboxed) are the ratios I need (PAL):
DVD 720 x 410 (letterboxed 720 x 576)
VCD 352 x 200 (letterboxed 352 x 288)
From what I have read, I know that the 16:9 done correctly can fill a 16:9 television (and 4:3 telly letterboxed), but I will also be wanting to have copies on my hard drive and AFAIK my PC will just play the squashed version (also need to experiment before I commit to 16:9 capture/encoding).
The answers regards the ratio, that I have found on my search only seem to apply to NTSC.
Thanks for any help.
Cole
vcd = cannot be anamorphic widescreen
dvd = can be anamorphic widescreen, but only @ 720/704, not 352 (half d1)
Thanks for the quick reply lumis, but I am not after creating an anamorphic - what I meant was if I have a squashed 16:9 picture to convert would I have to apply my figures to bring the picture only to the correct ratio.
I will still be encoding (the VCD for example) to 352x288 adding black bars top and bottom, but for the actual picture, would it be 352x200?Cole -
The picture would be 352x200(AddBorders(0,44,0,44).
Much appreciated johns0.
It should then follow that my DVD res. appears to right as well.
Thanks again.
Cole -
Yes, from what I have seen on my search, ultimately I will end up moving over to anamorphic DVDs. It was just I was initially a little reluctant to go down this path (i.e. resetting my digibox's output) with some of my captures just in case. But as I said, I will be doing some experimenting and get there in the end.
Cole
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 17:01 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 14:25 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 17:16 -
Correcting VCD aspect ratio?
By gastrof in forum Video ConversionReplies: 4Last Post: 30th May 2007, 14:43
