Im creating a DVD menu using DVD Lab Pro. The thing that is bothering me is I am using text buttons and they are showing up pink! I cannot seem to figure out how to change the color. I don't want pink text! I'm sure it's right in front of me, but can someone please tell me how to change this? Thanks.
Pink is your hilighted text color.
Look on the MAP tab, and select any colour you want, or turn off hilighting completely (slider all the way left).Cheers, Jim
My DVDLab Guides
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 07:03 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
DVD LAB PRO - color map
By blackmiles in forum Authoring (DVD)Replies: 5Last Post: 14th Apr 2010, 03:56 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 14:30 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32
